Detect all markers inside a given radius
2125
05-02-2014 01:44 AM
mxmx
I have a set of coordinates that is loaded from database. I would like to detect all the loaded markers that are close to each others
which is within a certain distance.
so the code is something like
function locatePOI() { // Places of Interest
    var Grid_Table = document.getElementById('PrimarySchoolDGV');
 var xmlhttp=new XMLHttpRequest();
 xmlhttp.open("GET", "/Foreigners@SG/WebService.asmx/getPlacesOfInterests", false);
 xmlhttp.send();
    var xmlDoc = xmlhttp.responseXML;
    var xmlalbums = xmlDoc.documentElement.getElementsByTagName("PlacesOfInterest");
    $.each(xmlalbums, function () {
        testindex = 0;
        var school = $(this).find("Name").text();
        var address = $(this).find("Address").text();
        var postalcode = $(this).find("PostalCode").text();
        var cat = $(this).find("Category").text();
        var incidentI = "";
        coordX = $(this).find("X").text();
        coordY = $(this).find("Y").text();
        var point = new esri.geometry.Point({ "x": coordX, "y": coordY, "spatialReference": { "wkid": 3414} });
       if(pointsbetweeneachother < 3km)
// do something here
        var symbol = new esri.symbol.PictureMarkerSymbol('images/icons/Interest-icon1.png', 25, 25);
        //symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, safetyLevelRadiusSize * 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([r, g, b, 0.5]), 10), new dojo.Color([r, g, b, 0.9]));
        var infoTemplate = new esri.InfoTemplate();
        infoTemplate.setTitle("<img src='images/icons/interest-icon.png' style='width:25px; height:25px;'/>   " + school);
        infoTemplate.setContent("<b>Food Establishments : </b>" + school + "</br>"
                    + "<b>Address: </b>" + address + "<br/>"
                    + "<b>PostalCode: </b>" + postalcode + "<br/>"
                   + "<b>Category: </b>" + cat + "<br/>"
        var graphic = new esri.Graphic(point, symbol);
        map.graphics.add(graphic);
        graphic.setSymbol(symbol);
        graphic.setInfoTemplate(infoTemplate);
can anyone help me with this?
NoppadonHimananto
 xmlhttp.send();
        testindex = 0;
        var incidentI = "";
I don't sure what u need.
But this example may be involve with what u want.
[ATTACH=CONFIG]33551[/ATTACH]
1. This example is I use geometry service to buffer a point with radius that I want and it return Geometry[] set.
https://developers.arcgis.com/javascript/jsapi/geometryservice-amd.html
https://developers.arcgis.com/javascript/jsapi/bufferparameters-amd.html
2. then i pass that Geometry set to geometry reference on QueryTask and execute to find what is in that geometry
3. then I highlight all object that is in radius.
On the Example's results isn't highlight all object in radius because QueryTask return only max 1000 results.
mxmx
Thank you for your reply. Unfortunately it is not what i wanted. I do not need a server to return me the coords.
I have already loaded it from database. However i want to detect if all the markers are close to each other by a certain distance..
