Dereference texture error logged when text symbol is removed from graphics layer
1896
06-05-2024 02:18 PM
TonySchwebach
I have a 3d SceneView with a graphics layer and a point graphic with icon and text symbol layers. When the graphic is removed from the graphics layer, the console logs this error message:
"4.29/:132 [esri.views.3d.webgl-engine.lib.TextureRepository.RefCountedTextureImpl] Cannot dereference texture that has no references!"
The error only seems to happen when the TextSymbol3DLayer() is included in the symbol layers. If it is commented out, there is no error message.
How can I avoid or suppress this error message?
I created the html page below which replicates the error when the "add/remove" button is clicked.
https://stackblitz.com/edit/stackblitz-starters-adfukf?file=index.html
<html lang="en">
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>
      Add Graphics to a SceneView | Sample | ArcGIS Maps SDK for JavaScript 4.29
    </title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.29/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.29/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 80%;
        width: 100%;
    </style>
    <script async defer>
      require([
        "esri/Map",
        "esri/views/SceneView",
        "esri/layers/GraphicsLayer",
        "esri/Graphic",
      ], (Map, SceneView, GraphicsLayer, Graphic) => {
        const map = new Map({
          basemap: "hybrid",
        const view = new SceneView({
          container: "viewDiv",
          map: map,
          camera: {
            // autocasts as new Camera()
            position: {
              // autocasts as new Point()
              x: -0.178,
              y: 51.48791,
              z: 1266.7049653716385,
         * Add graphics layer
        const graphicsLayer = new GraphicsLayer();
        map.add(graphicsLayer);
         * Add a 3D point graphic
        function addGraphic() {
          // London
          const point = {
            type: "point", // autocasts as new Point()
            x: -0.178,
            y: 51.48791,
          const markerSymbol = {
            type: "point-3d",
            symbolLayers: [
                type: "icon", // autocasts as new IconSymbol3DLayer()
                size: 8, // points
                resource: { primitive: "circle" },
                material: { color: "red" },
                type: "text", // autocasts as new TextSymbol3DLayer()
                text: `\n\n 100 m`,
                size: 10, // points
                halo: {
                  color: "white",
                horizontalAlignment: "center",
                verticalAlignment: "top",
          const pointGraphic = new Graphic({
            geometry: point,
            symbol: markerSymbol,
          graphicsLayer.add(pointGraphic);
        addGraphic();
        const removeButton = document.getElementById("remove-button");
        removeButton.addEventListener("click", (e) => {
          if (graphicsLayer.graphics.items.length) {
            try{
              graphicsLayer.removeAll();
            } catch (err){
              console.log('trying to catch the error', err)
          } else {
            addGraphic();
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
    <p>Open the console to see the error logged when removing a graphic with TextSymbol3DLayer</p>
    <button id="remove-button">add/remove</button>
  </body>
</html>
AndreV
We have the same problem in our application. I tried a lot of things, but I didn't come to a solution. But I do know that this bug already came up with 4.28. Maybe this helps the developers of esri.
gdi-hohenlohekreis.de
ThomasKnabl
Hi Tony,
Thanks for reaching out on this topic and the good repro case. This error shouldn't occour anymore in the upcoming release.
Best,
Thomas
LuisSolaRuiz
@ThomasKnabl @ We are using 4.30.9 version and still appearing this error in 3D mode using the following code. Should it be already solved? Thank
