Deployment issues of ESRI Js files
1039
05-22-2013 01:58 AM
ShashankA
Hi All,
I'm working on application where I'm displaying ESRI map along with some graphics added on to the map.
I'm using script files from the arcgisonline.com site.
Now my requirement is I do not want to point to arcgis server any more. So I want to the Js file to be referred locally. So can any    one tell me what are the files that I need to download and deploy them in my webserver to make ESRI API work properly.
Note:
I need to all the files which it takes to render the map and I'm using method to convert x and y values in to Latitude and Longitude and then Latitude and Longitude to 'X' and 'Y'  values based on the requirement.
Thanks in advance
BenFousek
