Deploy Code to Web App Builder Dev Edition
7130
25
07-10-2018 10:55 AM
TD1
I have some code that I want to deploy into my app created through web app builder developer edition. Where do I include my java script code to make this run correctly? I am new to web dev.
Thanks!
RobertScheitlin__GISP
joerodmey
Took a look but still unsure of how to implement as widget for WAB. Maybe I missed something?
Joe,
   Not sure why you would need to. Have you not seen the coordinate widget that comes with WAB?
Coordinate widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
joerodmey
Robert,
Looking to incorporate the capture x/y location code as mentioned above only when a widget is selected, create a hyperlink and pass the info to survey123. I have all of this functionality except being a widget in WAB
joerodmey
This code works except for one part...when other layers are added the popup box disappears but the purple dot sticks around when clicking on map.
TD1
Same thing happens for me. Curious to know if there is a solution
Just clear the maps graphics first then:
map.graphics.clear();
TD1
Popups still competing for screen space. I've had to disable all popups from my layers to allow this custom popup to display. Is there a workaround?
joerodmey
How can this x/y on mouse click be housed within a widget? I would like the user to have control over when this function is on or off.
Joe,
   The coordinate widget already does this.
