Dependent dropdowns in the editor widget entry form
976
02-04-2021 11:48 AM
workplayce2
Is it possible to set up dependencies between two dropdowns on the editor widget entry form, so that selecting one value will filter the other?
by Anonymous User
Not applicable
I think you can with setting up the edit widget with configurations.  Check out the esri example widgets-editor-configurable Think you could do it with using some switch cases for the selected value and the fields you want in the dropdown.
