delete markers on button click
4595
11
03-30-2020 05:38 AM
rsharma
Hi i want to delete markers individual markers from my graphics layer on button click
RobertScheitlin__GISP
Rajni,
   That delete button is inside the popup right? The popup is associated with a specific feature (graphic) so you can call view.popup.selectedFeature.attributes.xyz to get the graphics xyz attribute.
Rajni,
   You need to loop (map) through the graphicsLayer.graphics and look for the graphic that has the attribute you which to delete and call remove.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-GraphicsLayer.html#remove
rsharma
How to look for that exact marker which i want to delete on which i have clicked and delete button is on its popup.
I loop through marker layer and get all markers object in console, how to get exact current marker which is clicked
     jQuery('#main').on('click','.delete',function(){
            markerGL.graphics.map(function(gra){
              console.log(gra.geometry);
Assign each graphic a unique id attribute when it is placed.
rsharma
Ok if i assign unique id to each marker, how to use .remove function  on trash btn of each marker popup.
Loop through the graphics and check each graphics attribute for the one you are looking for and call markerGL.remove(graphic);
rsharma
How do i know , i am looking for that graphics as i just clicked on it and try t delete it.
how to find that marker which is clicked
Rajni,
rsharma
The same problem arise here that i have to click outside of editablepolygon first then only my marker is clickable??
This is behavior as designed.
