Dehighlighting a highlighted feature
4268
06-25-2015 05:33 AM
SatyanarayanaNarmala
hi all,
i have highlighted a point based on selection using
SelectedFindDeceasedName.setSymbol(highlightSymbol);
how can u dehighlight the same before highlighting the other point feature
thanks,
satya
RobertScheitlin__GISP
Satya,
  So if the symbol321 is the NORMAL symbol then you need to apply that symbol to each other graphic.
        dojo.forEach(map.graphics.graphics,function(graphic){
          //deselect all graphics first
          SelectedFindDeceasedName.setSymbol(symbol321);
          if((graphic.attributes) && graphic.attributes.FID === FindDeceasedName){
            SelectedFindDeceasedName = graphic;
            //Apply the highlight symbol to only the one that matches
            return;
Satya,
   You just use setSymbol again on that feature again and apply the normal symbol. I would normally set a global var for the current selected symbol that way you know which one to apply the normal symbol to.
TimWitt2
Satya,
check out this example: ArcGIS API for JavaScript Sandbox
they use a mouse-over event, first they clear all graphics and then they add a highlight graphic.
Tim
this is my code
initially set the symbol
symbol321 = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 0.1, null, new Color([255, 255, 0, 0.5]));
function onRowClickHandler(evt){
  var FindDeceasedName = grid.getItem(evt.rowIndex).FID;
        var SelectedFindDeceasedName;
            return;
        var FindDeceasedNameExtent = SelectedFindDeceasedName.geometry;
  var factor = 0.1;
  var extent;
        extent = new esri.geometry.Extent({ "xmin": FindDeceasedNameExtent.x - factor, "ymin": FindDeceasedNameExtent.y - factor, "xmax": FindDeceasedNameExtent.x + factor, "ymax": FindDeceasedNameExtent.y + factor, "spatialReference": { "wkid": 3857} });
  map.setExtent(extent);
still previously highlighted is not cleared.
Regds,
Satya
Satya,
            return;
Hi Robert,
  1. dojo.forEach(map.graphics.graphics,function(graphic){
  2.           //deselect all graphics first
  3.           graphic.setSymbol(symbol321);
  4.           if((graphic.attributes) && graphic.attributes.FID === FindDeceasedName){
  5.             SelectedFindDeceasedName = graphic;
  6.             //Apply the highlight symbol to only the one that matches
  7.             SelectedFindDeceasedName.setSymbol(highlightSymbol);
  8.             return;
  9.           }
  10.         });
Satya.
