Define DotNot Proxy in C#
2235
05-06-2021 01:55 PM
jaykapalczynski
Honored Contributor
In JavaScript I am adding a proxy rule as such....
urlUtils.addProxyRule({
	urlPrefix: "https://xxxx.xxxx.xxxx.gov/arcgis/rest/services/Testing/Test/FeatureServer/0",
	proxyUrl:  "https://xxxx.xxxx.xxxx.gov/DotNet/proxy.ashx"
But I have a .Net app that I need to call a GP Service from C#     BUT     I want to run it through the proxy so Credentials are not needed....
How would I modify this code to work in C# so I can use it to bypass credentials on a secured GP Service
	urlPrefix: "https://xxxx.xxxx.xxxx.gov/arcgis/rest/services/Testing/Test/GP_TOOL/",
jaykapalczynski
Honored Contributor
I got it with this....I went another route and got a Token for the service....I will simply apply that to the Service when I call it to satisfy the Credentials needed.
        // GET TOKEN
        public String GetToken()
            string result = null;
            try
                string gpUrl = "https://xxxx.xxxx.xxxx.gov/arcgis/tokens/generateToken?username=User&password=U$er&expiration=15&f=json";
                string reqString = gpUrl;
                HttpWebRequest req = WebRequest.Create(new Uri(reqString)) as HttpWebRequest;
                req.Method = "POST";
                req.ContentType = "application/json";
                // Encode the parameters as form data:
                byte[] formData = UTF8Encoding.UTF8.GetBytes(reqString);
                //req.contentLength = formData.Length;
                // Send the request:
                using (Stream post = req.GetRequestStream())
                    post.Write(formData, 0, formData.Length);
                // Pick up the response:
                //string result = null;
                using (HttpWebResponse resp = req.GetResponse() as HttpWebResponse)
                    StreamReader reader =
                    new StreamReader(resp.GetResponseStream());
                    result = reader.ReadToEnd();
                    Console.WriteLine(result.ToString());
                return result;
            catch (Exception ex)
                Console.WriteLine(ex.Message);
                result = ex.Message;
                return result;
jaykapalczynski
Honored Contributor
In my Web.config I have the URL referenced
      <setting name="deletePoints_Dev" serializeAs="String">
        <value>https://xxxx.xxxx.xxxx.gov/arcgis/rest/services/Testing/GPToolEditor/FeatureServer/0</value>
      </setting>
When I go to use this GP Tool I do this
        public Boolean DeleteAllPointsFromTable()
            try
                string whereClause = "OBJECTID>-1";
                string gpUrl = deletePoints_Dev;
                if (production) gpUrl = deletePoints_Prod;
                string reqString = gpUrl + "/deleteFeatures?where=" + whereClause;
BUT I am going to lok down this GP Tool URL like a Feature Service.  Where in this workflow would I add the Proxy to bypass this authentication?
WHERE do I put this Proxy Rule?
HOW do I write this in C#
			urlPrefix: "https://xxxx.xxxx.xxxx.gov/arcgis/rest/services/Testing/GPToolEditor/FeatureServer/0",
jaykapalczynski
Honored Contributor
jaykapalczynski
Honored Contributor
        // GET TOKEN
            try
                return result;
                return result;
