Default Editor - "Unable to complete operation."
1399
07-05-2012 07:30 AM
AdrianMarsden
Honored Contributor
Hi
I've taken the default editor from http://help.arcgis.com/en/webapi/javascript/arcgis/demos/ed/ed_default_editingwidget.html and pointed it at a feature service of mine.  It all displays all the edit stuff and allows me as far as clicking on a new location for the single point layer I have, but then nothing.  In the console I get a error with the message "Unable to complete operation."  The details of my feature layer are below.  Any ideas?
ACM
Display Field: field1
Type: Feature Layer
Geometry Type: esriGeometryPoint
Description:
Definition Expression: N/A
Copyright Text:
Default Visibility: true
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Min Scale: 0
Max Scale: 0
Supports Advanced Queries: true
Supports Statistics: true
Extent:
XMin: 287603.29310000036
YMin: 77481.15640000068
XMax: 336484.5109000001
YMax: 113666.57149999961
Spatial Reference: 27700  (27700)
Drawing Info:
Renderer:
Unique Value Renderer:
Field 1: field1
Field 2: null
Field 3: null
Field Delimiter: ,
Default Symbol:
Style: esriSMSCircle
Color: [0, 133, 163, 255]
Angle: 0.0
XOffset: 0
YOffset: 0
Outline:
[0, 0, 0, 255] Width: 1
Default Label:
UniqueValueInfos:
Value:
Label:
Description:
Symbol:
Color: [173, 38, 171, 255]
Angle: 0.0
XOffset: 0
YOffset: 0
Outline:
Value: A
Label: A
Description:
Symbol:
Color: [50, 133, 50, 255]
Angle: 0.0
XOffset: 0
YOffset: 0
Outline:
Value: B
Label: B
Description:
Symbol:
Color: [140, 57, 36, 255]
Angle: 0.0
XOffset: 0
YOffset: 0
Outline:
Transparency: 0
Labeling Info:
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field: field1
Fields:
OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID , editable: false , nullable: false )
field1 ( type: esriFieldTypeString , alias: field1 , editable: true , nullable: true , length: 50 )
field2 ( type: esriFieldTypeString , alias: field2 , editable: true , nullable: true , length: 50 )
GlobalID ( type: esriFieldTypeGlobalID , alias: GlobalID , editable: false , nullable: false , length: 38 )
Types:
ID:
Name:
Domains:
Templates:
Name:
Description:
Prototype:
field1:
Drawing Tool: esriFeatureEditToolPoint
Domains:
Templates:
Description:
Prototype:
field1: A
Domains:
Templates:
Description:
Prototype:
field1: B
Capabilities: Create,Delete,Query,Update,Uploads,Editing
Sync Can Return Changes: true
Is Data Versioned: true
Supports Rollback On Failure: false
FengZhang2
See if you can edit the layer in ArcMap. If not, check the featureclass in the SDE geodatabase.
AdrianMarsden
Honored Contributor
"no editable layers" so what have I missed in setting up the feature service.  The SDE account has write rights, the layer has a GUID (I'm not sure this is needed, but it is for ArcGIS for Mobile), it is versioned.  The Map Service is set for features?
Cheers
ACM
