Default Editing Widget - Capture Point
1731
04-22-2013 09:40 AM
JamesTrier
Apologies if a similar question was asked before...
When using the default editing widget (using code from this sample), how can I capture the the geometry of the user-added feature?  Using Firebug I can see this data in the JSON payload sent to the server during the ApplyEdits operation (i.e. XY coordinates of a new point).  Is there an event I can connect to in order to capture that data?
I tried:
//Try #1, didn't fire or give an error  dojo.connect(editorWidget, 'onDrawEnd', function(evt){      console.log(evt); });   //Try #2, nothing  dojo.connect(map.getLayer(featureLayer.id), 'onclick', function(evt){      console.log(evt); });
Thanks for your help!
Jim
ReneRubalcava
Esri Frequent Contributor
The 'onEditsComplete' event returns 3 arrays as it's arguments
addResults, updateResults, deleteResults
http://developers.arcgis.com/en/javascript/jsapi/featurelayer.html#onEditsComplete
dojo.connect(editorWidget, 'onEditsComplete', function(addResults, updateResults, deleteResults){      console.log('addResults: ', addResults);      console.log('updateResults: ', updateResults);      console.log('deleteResults: ', deleteResults); });
Similarly, you can capture the results before they are sent to the server, by listening for 'onBeforeApplyEdits'
http://developers.arcgis.com/en/javascript/jsapi/featurelayer.html#onBeforeApplyEdits
I think you can modify the edits, but cannot cancel them if something doesn't meet your criteria.
JakeSkinner
Esri Esteemed Contributor
Hi Jim,
You can do this using the "onEditsComplete" event along with the "onDrawEnd" event.  Here is an example:
dojo.connect(operationsPointLayer, "onEditsComplete", function(){
        var tb = new esri.toolbars.Draw(map);
        tb.activate(esri.toolbars.Draw.POINT);
        dojo.connect(tb, "onDrawEnd", function(geometry){
            console.log("X: " + geometry.x + ", Y: " + geometry.y);
        tb.deactivate();
JamesTrier
Hi Jim,
        tb.deactivate();
Thanks again for your help Jake... I tried 'onDrawEnd' the way you suggested, but no dice.  When I logged the 'onEditsComplete' event, I got a result, but not the one I expected:
//Event object
declaredClass : "esri.layers.FeatureEditResult",
objectId : "208281",
success : "true"
Since I get the ObjectId from onEditsComplete, maybe I can search the map for that object and get the XY that way?  I'm not sure if there's a more efficient or better way to do it...
Also, a question on the draw functions:  Doesn't picking a selection in the Editor widget turn on the draw toolbar just for that selection?  When I tested it, I had to select an editor to drop a point, and then select again to drop another point.
Is there a way to look at the data from the edit pre-flight, like a 'beforeEdits' event?  My Google-Fu didn't find anything like that.
Thanks again for taking a look!
ReneRubalcava
JamesTrier
Rene, that's precisely what I needed!  I connected to 'onBeforeApplyEdits' and got the data payload before sending to the server.  From there I found the XY I needed.
            dojo.connect(featureLayer, "onBeforeApplyEdits", function(e){
                var newPointX = e[0].geometry.x, newPointY = e[0].geometry.y;
                //Go to town from here
Sincerely appreciate the help, thanks!
