Deactivate visibility of a html-element after activating the basemapgallery via Expand-button
1519
08-01-2024 01:46 AM
KaiBehncke
Daar users,
in my application I have a map-div and a "layer-selection-span":
   <div id="viewDiv">
        </div>
        <span id="layerToggle">
          <input type="checkbox" id="kanalLyr" checked> Kanal
        </span>
Furthermore I use an Expand to show the BaseMapGallery:
var basemapGallery = new BasemapGallery({
            view: view,
            source: initBasemap,
            container: document.createElement("div")
          var bgExpand = new Expand({
            view: view,
            expandTooltip: "Basiskarten",
            content: basemapGallery
          view.ui.add(bgExpand,{
              position: 'bottom-left',
I try to find a solution that the
 span id="layerToggle" is not visible anymore, if I open the BasemapGallery (and that it is visible, if I close the BaseMapGallery).
I tried things like:
bgExpand.addEventListener("click",event=>{
or:
bgExpand.on("click", function(event){
...but without success. Can anybody help please? How can I start a function after clicking on the Expand-Button?
Tags (1)
2 Solutions
AnneFitz
Hi - you can watch the expanded property on the Expand widget to know whether it is expanded/collapsed and then update the visibility of your layerToggle. Here's an example: https://codepen.io/annefitz/pen/gONmeMR?editors=100
bgExpand.watch("expanded", () => {
   document.getElementById("layerToggle").style.display = bgExpand.expanded ? "none" : "block";
KaiBehncke
Thank you very much, Anne, good solution  !
Another solution for the described problem is:
 reactiveUtils.watch(
    () => [bgExpand.expanded], ([bgExpand]) => {
       if (bgExpand==true) (document.getElementById("layerToggle").style.visibility="hidden");
       if (bgExpand==false)(document.getElementById("layerToggle").style.visibility="visible");
AnneFitz
KaiBehncke
