Date field formats using both Query and Identify Tasks
2859
05-05-2010 06:35 AM
SteveDale
I have noticed that the Query Task and the Identify Task return date field values in a different format.
ie.. The id format is returning 10/16/2010 (mm/dd/yyyy)
     The query format is returning a longer date format such as Mon Oct 04 00:00:00 EDT 2010
How can I control the display format of the date for both id and query without having to parse out each type differently.  It will also change when I go to either a UNIX or Windows server.  I am using ArcGIS Server 9.3.1 on both windows and unix servers, and the Javascript api 1.6.
Thanks in advance for any help..
Steve
AlessioDi_Lorenzo
I solved using this jQuery plugin on the client-side...
usage example:
jQuery.format.date(attributes["DATE_ATTR"],"dd/MM/yyyy")
