DataGrid with zoom button...button doesn't show and won't zoom
6138
16
01-30-2014 05:23 AM
MichelleRogers1
I am new at working with ArcGIS API for JavaScript and have come across the following problem:
I am working with the sample DataGrid with zoom button to get my data to zoom to a specific point, but not only is the data not zooming, the button isn't even showing inside the grid.  Instead it is showing the OBJECTID.  Any suggestions on how to fix this?
Here is part of the  JavaScript code I am working with:
policeUnits2 = new esri.layers.FeatureLayer
("http://GIS10204:6080/arcgis/rest/services/GeoEvent/gx440P/MapServer/0",{
mode:esri.layers.FeatureLayer.MODE_SELECTION,
outFields:["VehicleId", "Velocity", "OBJECTID"]
//define a selection symbol
var highlightSymbol = new esri.symbol.SimpleFillSymbol().setColor( new dojo.Color([50,205,50,.25]));
policeUnits2.setSelectionSymbol(highlightSymbol);
dojo.connect(policeUnits2,'onLoad',function(layer){
var query = new esri.tasks.Query();
query.where = "1=1";
layer.queryFeatures(query,function(featureSet){
  var items = dojo.map(featureSet.features,function(feature){
   return feature.attributes;
  var data = {
   identifier:"OBJECTID",
   items:items};
  store = new dojo.data.ItemFileReadStore({data:data});
  grid.setStore(store);
  grid.setSortIndex(1,"true"); //sort on VehicleId
map.addLayer([policeUnits2]);
//modify the grid so only the VehicleId field is sortable
grid.canSort = function(col){ if(Math.abs(col) == 2) { return true; } else { return false; } };
function makeZoomButton(id){
var zBtn = "<div data-dojo-type='dijit/form/Button'><img src='images/zoom.png'";
zBtn = zBtn + " width='18' height='18'";
zBtn = zBtn + " onClick=\"zoomRow('"+id+"')\"></div>";
return zBtn;
function zoomRow(id){
policeUnits2.clearSelection();
query.objectIds = [id];
policeUnits2.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW,function(features){
  //zoom to the selected feature
  var unitExtent = features[0].geometry.getExtent().expand(1.0);
  map.setExtent(unitExtent);
This is the html code:
<body class="claro">
<div data-dojo-type="dijit/layout/BorderContainer" style="width: 100%; height: 100%">
  <div data-dojo-type="dijit/layout/ContentPane"  id="header" data-dojo-props="region:'top'">City of Naples Police AVL
   <div id="locateContainer">
    <label>Address: </label>
    <input id='addressInput'></input>
   </div>
  </div>
  <div id="mapDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
   <div id="BasemapToggle" ></div>
   <div id="HomeButton"></div>
  </div>
  <div data-dojo-type="dijit/layout/ContentPane" id="leftPane" data-dojo-props="region:'leading'">
   <table data-dojo-type="dojox/grid/DataGrid" jsid="grid" id="grid" selectionMode="none">
    <thead>
     <tr>
      <th field="OBJECTID" formatter="makeZoomButton" width="25px">
      <img alt="+" src="images/zoom.png"/>
      </th>
      <th field="VehicleId" width="100px">Vehicle Id</th>
     </tr>
    </thead>
   </table>
  </div>
        </div>
</body>
Here is a picture of what my viewer looks like
[ATTACH=CONFIG]30965[/ATTACH]
Any help would be very much appreciated!
Michelle
JakeSkinner
Esri Esteemed Contributor
Take a look at the jsfiddle here.  The only thing I changed was the map extent, and the service to the Vehicle layer.
MichelleRogers1
This data is coming in from the GeoEvent Processor.  Could this have an effect on the zoom to?  Do we need to contact someone with GeoEvent Processor experience?
MichelleRogers1
I was able to get the issue narrowed down to an issue with the Home Button, Basemap Toggle, and InfoTemplate interferring with the DataGrid.  I started out with the DataGrid with zoom button sample code and started entering items until it no longer worked to get to this point.  Is there anything that can be done to get those three functions into code with the DataGrid?  When I go to insert those three functions, the entire screen except the header is completely blank.  I am also trying to get the DataGrid to do an automatic refresh as well, so any help you can give me with that would be appreciated as well.
Here is the code I am working with now.
<!DOCTYPE html>
<html>
  <head>
    <title>Cityof Naples Police AVL</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dojox/grid/resources/Grid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
    <style>
      body,html,#main{margin:0;padding:0;height:100%;width:100%;}
      #map{
  padding:0;
  border:solid 1px;
   #HomeButton{
  position:absolute;
  top:90px;
  left:20px;
  z-index:50;
   #header{
  font-weight:600;
  font-size:14pt;
  padding-left:20px;
   #locateContainer{
  position:absolute;
  right:10px; top:5px;
  border-radius:5px;
    </style>
    <script>var dojoConfig = { parseOnLoad:true };</script>
    <script src="http://js.arcgis.com/3.8/"></script>
    <script>
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
      dojo.require("dojo.parser");
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.form.Button");
      dojo.require("dijit.form.TextBox");
      dojo.require("dojox.grid.DataGrid");
      dojo.require("dojo.data.ItemFileReadStore");
   dojo.require("dojo.data.ItemFileWriteStore");
      var map, statesLayer;
  function init() {
        map = new esri.Map("map",{
          basemap: "topo",
          center: [-81.797, 26.153],
          zoom: 12
        //add the states demographic data
  var policeUnits = new esri.layers.ArcGISDynamicMapServiceLayer("http://GIS10204:6080/arcgis/rest/services/GeoEvent/gx440P/MapServer")
  map.addLayer(policeUnits);
  policeUnits.setRefreshInterval(0.083);
  //Address Locator
  dojo.connect(dojo.byId("addressInput"), 'onkeyup',function(event){
   if(event.keyCode == 13 && this.value.length>0){
   locateAddress(this.value);
 function locateAddress(atText){
  var l = esri.tasks.Locator('http://gis.naplesgov.com/naplesgis/rest/services/Locators/Naples_Address_Locator/GeocodeServer');
  l.outSpatialReference = map.spatialReference;
  var params = {address : {'Single Line Input': atText}};
  l.addressToLocations(params, function(c){
  if(c.length == 0){
   alert("No location found at this address");
  var currentLoc = c[0].location;
   map.centerAndZoom(currentLoc,19);
  function(){
   console.log("No location found at this address");
        statesLayer = new esri.layers.FeatureLayer("http://GIS10204:6080/arcgis/rest/services/GeoEvent/gx440P/MapServer/0",{
          outFields:["VehicleId","Velocity","OBJECTID"]
        var highlightSymbol = new esri.symbol.SimpleMarkerSymbol({
                    "color":[0,112,255,255],
                    "size":14,
                    "angle":0,
                    "xoffset":0,
                    "yoffset":0,
                    "type":"esriSMS",
                    "style":"esriSMSDiamond",
                statesLayer.setSelectionSymbol(highlightSymbol);
        dojo.connect(statesLayer,'onLoad',function(layer){
            var data = {
              items:items};
            grid.setSortIndex(1,"true"); //sort on the state name
        map.addLayers([statesLayer]);
  var cityLimits = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.naplesgov.com/naplesgis/rest/services/City/CityLimits/MapServer");
   map.addLayer(cityLimits);
  var addressPoints = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.naplesgov.com/naplesgis/rest/services/City/AddressPointSlbl/MapServer");
   map.addLayer(addressPoints);
        //modify the grid so only the STATE_NAME field is sortable
   function pointToExtent(map, pointX, pointY){
                    var xmin = pointX - 100;
                    var ymin = pointY - 100;
                    var xmax = pointX + 100;
                    var ymax = pointY + 100;
     return new esri.geometry.Extent(xmin, ymin, xmax, ymax, map.spatialReference)
        var zBtn = "<div data-dojo-type='dijit.form.Button'><img src='images/zoom.png'";
        return zBtn;
        statesLayer.clearSelection();
        statesLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW,function(features){
          extent = pointToExtent(map, features[0].geometry.x, features[0].geometry.y)
    map.setExtent(extent);
   //function(DataGrid, ItemFileWriteStore){
   //if policeUnits.setRefreshInterval()==true;
  //var newStore = new ItemFileReadStore({data: {data});
  //var grid = dijit.byId("gridId");
  //grid.setStore(newStore);
      dojo.ready(init);
    </script>
  </head>
    <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
   <div data-dojo-type="dijit.layout.ContentPane"  id="header" data-dojo-props="region:'top'">City of Naples Police AVL
        </div>
      </div>
      <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'" >
      </div>
      <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width:142px">
        <table data-dojo-type="dojox.grid.DataGrid" jsid="grid" id="grid" selectionMode="none">
         <thead>
            <tr>
              </th>
   </tr>
          </thead>
        </table>
      </div>
    </div>
  </body>
</html>
JonathanUihlein
Hi Michelle
I have some time to take a look at your code.
In the future, you should use http://jsfiddle.net to generate a working, live sample.
It makes debugging much easier.
MichelleRogers1
Hi Michelle
Jonathan,
I figured out my issue with the Basemap Toggle, Home Button, and Info Template.  I was trying to pass them through another function within the init function, which you do not need to do.  I just had to add the dojo.require statements for the three and then when I said new, instead of just:
var home = new HomeButton
use:
var home = new esri.dijit.HomeButton
I am still looking at how I can do an automatic refresh on the DataGrid itself, so any help there would be appreciated.
JonathanUihlein
Hi Michelle.
I spent some time on this yesterday but did not realize your application was written in the old style so I put it aside.
Jake's code is in the newer style (AMD) and on the right track but I personally would use a dgrid instead of DataGrid.
As for the issue, yep that's exactly it!
When coding in the legacy style, you will need to require each module individually and invoke using the same path pattern.
New Style (AMD):
require([
  "esri/map",
  "esri/dijit/HomeButton"
], function (Map, HomeButton) {
  var home = new HomeButton();
Old Style (Legacy):
dojo.requrie("esri.Map");
dojo.requrie("esri.dijit.HomeButton");
var home = new esri.dijit.HomeButton();
Is there any reason you are writing your application in the legacy style?
It will be deprecated sooner than later and I only bring it up so you aren't forced to rewrite the entire application somtime in the next year.
MichelleRogers1
Jonathan,
We tried using AMD from the samples for Home Button, Basemap Toggle, and Info Template, but when combined with the DataGrid, the DataGrid was not functioning anymore.  We were told to use DataGrid for the functionality that we wanted by an ESRI Technical Support person (Noah).  So, we decided to work in the reverse order, and the original code for DataGrid with zoom button in the ESRI Samples was written in Legacy.  So, I went in and added those functions in the Legacy code to get the entire application to work together.  If there is a way I can get everything to work in AMD, I am open to suggestions.  Like I had said at the beginning of the thread, I am new to coding with ESRI, and fairly new to coding in general, so any help you can give me is very much appreciated.
Michelle
