data marker
1442
05-10-2011 11:59 AM
JulieRecker
i am currently rewriting a google maps (API v.2) viewer in arcgis for javascript. i have several points that i query a database for and display on the map, with associated info window on click. in google maps, you use the GMarker. what is the best way using arcgis for javascript. map.graphics? a feature layer?
StephenLead
Honored Contributor
Hi Julie,
You'd probably want to use graphic objects to replicate this. See the sample at http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/graphics_multi... to get started.
Good luck,
Steve
JulieRecker
thanks for the response. what i'm trying to do is pull x,y coordinates from a database, and put them as point markers on the map. with an info window, of course. so, i'm not querying layers?
KellyHutchins
Esri Notable Contributor
The sample Steve pointed you to (Multiple Graphics Layers) is a good one for getting started. In that sample the graphics are generated as the results of a query - so you'll need to modify the code to loop through your database results and add a graphic for each point.
An alternate approach might be to use a feature layer. I've attached an example that gets geo-tagged photos from Flickr and displays them on a map. To view the attachment, rename the file extension to .html.
JulieRecker
thanks for the example kelly. i was trying to create an object esri.geometry.point, while using lat./long. instead of x,y. the following made all the difference:
var geometry = esri.geometry.geographicToWebMercator(new esri.geometry.Point(item.longitude, item.latitude));
this is exactly what i needed. thanks guys!
