Data Grid Related Records Zoom
3530
02-20-2015 09:03 AM
RickeyFight
In my web-app I can select a feature and open an attribute table that shows related fields.
But I cannot figure out what to add to the code to zoom to the location of a related record when I click on the table.
// DataGrid //
  //add a link to the popup that for getting related records
        var link = domConstruct.create("a",{
          "class": "action",
          "id": "relatedLink",
          "innerHTML": "Show Related Records", //text that appears in the popup for the link
          "href": "javascript: void(0);"
        }, query(".actionList", this.map.infoWindow.domNode)[0]);
        on(link, "click", function(){
          //Get info from the selected feature
          var feature = map.infoWindow.getSelectedFeature();
          var layer = feature.getLayer();
          var OIDField = layer.objectIdField;
          var oids = feature.attributes[OIDField];
          //Setup the relationship query
          var relatedQuery = new RelationshipQuery();
          relatedQuery.outFields = ["ROUTE_1","ROUTE_2","NAME","GROUP_","LENGTH", "OBJECTID"];
          relatedQuery.relationshipId = 0;
          relatedQuery.objectIds = [oids];
          //Perform the query
          layer.queryRelatedFeatures(relatedQuery, function(relatedRecords){
            //get the related records for the input OID. In this case there
            //is just one object id.
            clearGrid();
            var featureSet = relatedRecords[oids];
            if(featureSet && featureSet.features){
             createTable(featureSet);
            }else{
              console.log("No related records");
function clearGrid(){
        //clear existing grid
        if(grid){
            grid.set("store",new Memory({data:[]}));
            domUtils.hide(grid.domNode);
      function createTable(featureSet, info){
        var data = [];
        array.forEach(featureSet.features, function(r){
          data.push(r.attributes);
        //define the columns
        var relatedLayer = featureSet.features[0].getLayer();
        var columns = {
        var memoryStore =  new Memory({data: data});
        grid = new Grid({
          columns: columns
        },"tableContainer");
        grid.set("store", memoryStore);
        domUtils.show(grid.domNode);
