Data actions in ExB Dev Edition 1.19
949
7
02-19-2026 05:58 PM
NZGIS
Posting again in this group as this seems like the right place.
Hello ExP Builder community! First time poster here. We have just upgraded our Dev edition from 1.17 to 1.19 and we are seeing this weird issue appear with data actions.
When we click through the data actions from any widget, we have noticed that some options (for e.g. Add Marker) expand to a "Map" option twice. When we refresh, this map option appears under a different option (e.g. export), and on further refreshes this appear under different option.
Screenshot here -https://imgur.com/a/fh0SGlp. Has anyone come across this before, or am I missing something here. Any help is appreciated. TIA!
ToddW_stl
do you have 2 different Map widgets in your app?
NZGIS
I replied below through comments.
Sorry still learning how to use this forum.
NZGIS
No, only one.
NZGIS
On refreshing, it tends to appear twice, thrice.
ToddW_stl
i was able to reproduce and have asked developers if this is a known issue.  feel free to log a case with Esri technical support and share the case number here so others can reference it if they are also affected.
ToddW_stl
as @JeffreyThompson2 mentioned on your other post in the ExperienceBuilder community page - I've added the "multiple map" notes internally to existing BUG-000182651
NZGIS
Thanks @ToddW_stl ! Appreciate the support here.
