Customized API to location details from Feature service
1157
03-28-2025 06:17 AM
vijaybadugu
I was trying to create a customized api which internally sends a request to geocode service , pass the point to our own feature service to get other attribute information and return same thing in json format. i was planning to use JavaScript api to manage above functionalities. However, How to provide a API End point to the user and they can consume to get the customized output in json. I would have given directly feature service URL, However,  it does only limited functionality. I want to add multiple functionalities in to it like geocoding, pass the point to different feature services to get the linked information
Noah-Sager
The locator class with have some useful methods:
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-locator.html
And you might want to check out REST JS for this sort of work:
https://developers.arcgis.com/arcgis-rest-js/
by Anonymous User
Not applicable
JS Maps SDK is just a front end library. To build APIs with JS, you should probably use a framework that handles back end, like Express, Next.js, etc.
You would set up routing so that whenever user requests a specific URL, your server would run a custom function and return its result to the user. Inside that function you can use whatever library you want, including JS Maps SDK.
Noah-Sager
vijaybadugu
Thank you .
