Customize view.popu.open featureMenuOpen display
975
10-25-2022 10:11 AM
MatthewDriscoll
I was wondering if its possible to customize how the featureMenuOpen option for the popup.open of the popup template.  The default is for it to display the title of the popup template.  Basically I want to display the menu options as a table, but not the final popup.  See below.
Desired Menu
Desired Popup
Not wanted Popup if I use the desired menu
function getResults(results){
      // get the resulting query features and set the symbology for the graphics layers to display the results
      const searchResults = results.features.map(function(feature){
        // popup for the result(s)
        feature.popupTemplate = createPopupTemplate();
        return feature
      // response handlers from to many or not enough results.
      if(searchResults.length > 100){
        alert("Over 100 query results found, please provide a more specific query!");
      if(searchResults.length == 0){
        alert("No results found for this query!")
      else if(searchResults.length <= 100){
        resultsLayer.addMany(searchResults);
      // add the popup of the results to the view
      theView.popup.open({
        features: searchResults,
        featureMenuOpen: true,
        //closeButton: true,
        title: "testst",
        collapsed: true
function createPopupTemplate(){
      const urlTax = "https://";
      const urlRC = "https://www."
      var parInfo = 'https://www.html';
      return{
        title:
          "<b>Owner: </b> {PartyName}" +
          "<b>Address: </b> {PropertyAddress}" +
          "<b>Property Number: </b> {PropertyNumber}", //+
          //"<table>" +
          //"<tr><th>Owner:</th><th>Address:</th><th>PropertyNumber</th></tr>" +
          //"<tr><td>{PartyName}</td><td>{PropertyAddress}</td><td>{PropertyNumber}</td></tr></table>",
          //"<a class='hyperlinkURL2' target='_blank' href='#{Plat_HL}'>View Plat</a>",
        outFields: ["*"],
        content:
              type: "fields",
              fieldInfos:[
                  fieldName: "QuickRefID",
                  label: "Quick Ref ID",
                  fieldName: "ACRES",
                  label: "Acres",
                  format:{
                    places: 2,
                  fieldName: "RP_AprTot",
                  label: "Total Appraised Value",
                  format: {
                    places: 2,
                    digitSeparator: true,
              type: "text",
              text: "<a class='hyperlinkURL' target='_blank' href=" + parInfo + "?PropertyID={PropertyID}&PID={PID}&PropNum={PropertyNumber}>Parcel Information</a>&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp<a class='hyperlinkURL' target='_blank' href=" + urlTax + "PID={PID}>Tax Information</a>"
              type: "text",
              text: "<a class='hyperlinkURL2' target='_blank' href=https://{expression/platlinked}>View Plat</a>&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp<a class='hyperlinkURL' href=" + urlRC + "{PropertyNumber}.pdf>Property Record Card</a>",
          expressionInfos:[
              expression: platy,
