Customize the legend  elements
1749
10-22-2012 11:49 PM
SunilPalkar
Hello All,
I want to customize the legend box elements .Please check the screenshot (I want to remove the highlighted information ...its the map service name and symbol in ArcMap)
[ATTACH=CONFIG]18636[/ATTACH]
How its possible? Is there any way or Are there any parameter in the legend constructor ??
I tried to modify following code but it was not successful
 dojo.connect(map,'onLayersAddResult',function(results){           var layerInfo = dojo.map(results, function(layer,index){             return {layer: abc,title: 'new legend'};           });           if(layerInfo.length > 0){             var legendDijit = new esri.dijit.Legend({               map:map,               layerInfos:layerInfo             },"legendDiv");             legendDijit.startup();           }         });
Any help will be great...
Thanks in advance : )
CorySilva
You can use CSS (display:none; visibility:hidden) for the name of the layer.  As for the second two lines I believe you can remove those in the symbology settings in the actual mxd/msd.
CorySilva
SunilPalkar
Dear Coryasilva,
Thanks for your reply..I tried your method and its resolved : )
You are great !!!
