Customization of Shortlist app
1755
03-06-2019 09:10 PM
GeorgieCassar1
Has anyone downloadedthe shortlist app template and customized it to enable the feature description content panel to display images and web page links ?
Out of the box just enables plain text (content stored in descrption field in the feature layer.)
In other words I would like the content panel to be more like that in the Journal app template.
Any suggestions welcome.
BirajaNayak
This below link may help:
Working with Story Map Journal (and Shortlist) on different screen sizes
Otherwise, the best site to answer your queries is below:
Story Maps
Biraja
BirajaNayak
Story Maps
Biraja
GeorgieCassar1
Thank you very much for the tips.  If I build a shortlist from scratch using the builder, it's not possible to add html tags.
But using your links I found that if I use the CSV template to create a feature class, it offers 5 description fields and these can be populated with html tags directly to include images, hyperlinks etc.  This is called the 'as is' option as described here. Esri Story Maps - FAQ
The template and field descriptions can be downloaded with this :
http://links.esri.com/storymaps/shortlist_layer_template
And here's a tip to ensure your images fit nicely into any size of detail panel.  Use the max_width property with a calculation  :
<img style="max-width: calc(100% - 20px);" src="...your image url..." alt=" ">
