Custom tile URL. What type of layer should I use?
690
11-13-2013 05:49 AM
AndreyLabodin
Hello.
I have a source of tiles with the following URL format:
http://tiles.XXXX.com/map/lv10/00/000/000/616/000/000/700.png?key=XXXXXX
I know how to work with that kind of URLs with OpenLayers, but I can't find a way to make it with ArcGIS API for Javascript.
The tiles are in World Mercator spatial refference (EPSG:3395)
Should I use the WebTiledLayer or something else?
That is how it's done with OpenLayers:
<script defer="defer" type="text/javascript">
    var CENTER = {
        LON: 4187123.4301231, LAT: 7471123.1641231
    function getTileURL(bounds) {
        var coords = bounds.getCenterLonLat()
            , resolutions = ['dummy'
                    , 78271.51696484375,
                    39135.758482421875,
                    19567.8792412109375,
                    9783.93962060546875,
                    4891.969810302734375,
                    2445.9849051513671875,
                    1222.99245257568359375,
                    611.496226287841796875,
                    305.7481131439208984375,
                    152.87405657196044921875,
                    76.437028285980224609375,
                    38.2185141429901123046875,
                    19.10925707149505615234375,
                    9.554628535747528076171875,
                    4.7773142678737640380859375,
                    2.38865713393688201904296875,
                    1.194328566968441009521484375
            , fMinX = -20037508.343
            , fMinY = -19930481.933
            , zoom = this.map.getZoom()
            , fTileSizeMerc = resolutions[zoom] * 256
            , x = parseInt((coords.lon - fMinX) / fTileSizeMerc)
            , y = parseInt((coords.lat - fMinY) / fTileSizeMerc);
   var a = 'http://tiles.XXXX.com/map/' + 'lv' + (zoom +'00'+ (1000000000 + x).toString().substr(1)
                + (1000000000 + y).toString().substr(1)).replace(/^(\d{1,2})00(\d{3})(\d{3})(\d{3})(\d{3})(\d{3})(\d{3})/
                , '$1/00/$2/$3/$4/$5/$6/$7')
                + '.png?key=XXXXXX';
            return a;
    var map = new OpenLayers.Map('map')
    , xxMapBounds = new OpenLayers.Bounds(-20037508.343, -19930481.933, 20037508.343, 20144534.753)
    , params = {
        maxExtent: xxMapBounds,
        getURL: getTileURL,
        numZoomLevels: 18,
        transitionEffect: "resize",
        maxResolution: 156543.03390625,
        attribution: '<a href="http://XXXXX/">XXXXX JSAPI</a>'
    , xxMaps = new OpenLayers.Layer.OSM("XXXXX", 'http://XX.tiles.XXXXX.com/map/', params);
    map.addLayers([xxMaps]);
    map.addControl(new OpenLayers.Control.LayerSwitcher());
    map.zoomToMaxExtent();
    map.setCenter(new OpenLayers.LonLat(CENTER.LON,  CENTER.LAT), 10);
</script>
