Custom tile layer bug
1395
11-10-2019 04:15 AM
EfimDezhin
I try to reproduce custom tile layer (here) but it show me wrong tiles.
Is it bug? Is it possible to fix?
Kind regards,
Efim Dezhin
RalucaNicola1
Hi Efim,
this is a documentation problem, I'll work on getting this fixed in the next documentation update. Until then, the solution is to pass the AbortSignal in the esriRequest method:
// This method fetches tiles for the specified level and size.
// Override this method to process the data returned from the server.
fetchTile: function(level, row, col, options) {
   // call getTileUrl() method to construct the URL to tiles
   // for a given level, row and col provided by the LayerView
   var url = this.getTileUrl(level, row, col);
   // request for tiles based on the generated url
   return esriRequest(url, {
      responseType: "image",
      signal: options.signal
   }).then(...)
Here's the working sample: https://codepen.io/ralucanicola/pen/abbjwax?editors=1000
Thank you for reporting this!
