custom template-based widget does not work correctly
3924
7
04-07-2016 10:31 AM
Mariagomez1
Hello everybody,
I tried to make simple my codes in order to make easy solving the problem.. It is a widget with a template that shows when i click a button and when i click on map, in console line, a message tell " map is clicked". the problem is that the template does not show when i click the button and message does not appear in console line.
please help me, I have spend long time to solve this problem but i could not find any solution. Thanks in advance.
index.html  :
<!DOCTYPE HTML>
<html>
<head>
  <meta charset="utf-8">
  <link rel="stylesheet" href="arcgis_js_api/library/3.14/3.14/esri/css/esri.css">
  <link rel="stylesheet" href="arcgis_js_api/library/3.14/3.14/dijit/themes/nihilo/nihilo.css">
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
  <meta http-equiv="X-UA-Compatible" content="IE=Edge" />
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Y2K Map</title>
  <link rel="stylesheet" href="css/y2k.css" />
  <script>
   var dojoConfig = {
   async: true,
   packages: [{
   location: location.pathname.replace(/\/[^\/]*$/, '') + '/js'
  </script>
  <script src="arcgis_js_api/library/3.14/3.14/init.js" data-dojo-config="async: true"></script>
  </head>
  <body class="nihilo">
  <div id="mainwindow"
   data-dojo-type="dijit/layout/BorderContainer"
   data-dojo-props="design:'headline',gutter:false,
  liveSplitters: true"
   style="width: 100%; height: 100%; margin: 0;">
  <div id="header"
   data-dojo-type="dijit/layout/ContentPane"
   data-dojo-props="region:'top',splitter:true">
  <h1>Year 2000 Map</h1>
  <div id="buttonbar">
  <button id="census-btn" data-dojo-type="dijit/form/Button">Census</button>
  </div>
  </div>
  <div id="map" data-dojo-type="dijit/layout/ContentPane"
   data-dojo-props="region:'center',splitter:true">
  <div id="census-widget"></div>
  </div>
  <div id="footer"
   data-dojo-props="region:'bottom',splitter:true"
   style="height:21px;">
  <span>Courtesy of the Y2K Society</span>
  </div>
  </div>
  <script type="text/javascript" src="js/app.js"></script>
  </body>
  </html>
app.js :
require([
"dojo/parser",
"dojo/_base/lang",
"esri/map",
"y2k/Census",
"dijit/layout/ContentPane",
"dijit/layout/BorderContainer",
"dijit/form/Button",
"esri/geometry/Extent",
"dijit/registry",
"dojo/dom",
"dojo/domReady!"
], function(
  parser,
  dojoOn,
  lang,
  map,
  Census,
  ContentPane,
  BorderContainer,
  Button,
  Extent,
  registry,
  dom
  parser.parse();
   var bounds = new esri.geometry.Extent({
   "xmin":817962,
   "ymin":-187036,
   "xmax":1566109,
   "ymax":785554,
   "spatialReference":{"wkid":32640}
   var map = new esri.Map("map", {
  extent: bounds
   var census = new Census({
  map: map,
  mapService: "http://localhost:6080/arcgis/rest/services/sdeMXD/MapServer/"
   }, "census-widget");
   var censusBtn = registry.byId("census-btn");
  censusBtn.on("click", lang.hitch(census, census.show));
Census.js :
define([
   "dojo/_base/declare",
   "dijit/_WidgetBase", "dijit/_TemplatedMixin",
   "dijit/_OnDijitClickMixin",
   "dojo/dom-style",
   "dojo/text!./templates/Census.html",
   "esri/tasks/IdentifyParameters",
   "esri/tasks/IdentifyTask",
   "esri/InfoTemplate",
   "dojo/on",
   "dojo/_base/lang",
   "dojo/dom"
   function (declare, _WidgetBase, _TemplatedMixin,
  _OnDijitClickMixin, domStyle, dijitTemplate, IdentifyParameters, IdentifyTask,
  InfoTemplate,dojoOn, lang, dom ) {
   return declare([_WidgetBase, _TemplatedMixin, _OnDijitClickMixin], {
  baseClass: "y2k-census",
  templateString: dijitTemplate,
  constructor: function (options, srcRefNode) {
  console.log("we are in constructor ");
   if (typeof srcRefNode === "string") {
  srcRefNode = dom.byId(srcRefNode)
   this.map = options.map || null;
   this.domNode = srcRefNode;
  show: function () {
  domStyle.set(this.domNode, "display", "block");
   this._mapClickHandler = this.map.on("click", lang.hitch(this, this._onMapClick));
  hide: function () {
  domStyle.set(this.domNode, "display", "none");
   if (this._mapClickHandler && this._mapClickHandler.remove) {
   this._mapClickHandler.remove();
  _onMapClick: function (event) {
  console.log("map is clicked");
census.html :
<div class="${baseClass}" style="display: none;">
  <span class="${baseClass}-close"
   data-dojo-attach-event="ondijitclick:hide">X</span>
  <b>Census Data</b><br />
  <p>
  Click on a location in the United States to view the census data for that region.
  </p>
</div>
y2k.css:
html, body {
border: 0;
margin: 0;
padding: 0;
height: 100%;
width: 100%;
font-size: 14px;
h1 {
margin: 2px 8px;
display: inline-block;
*display: inline; /* IE 7 compatible */
zoom: 1; /* IE 7 compatible */
#buttonbar {
position: absolute;
top: 10px;
right: 15px;
width: auto;
height: auto;
#mainwindow,
#mainwindow .dijitSplitter {
  background: #fffaa9; /* paler yellow */
#header, #footer {
  -moz-border-radius: 5px;
  -webkit-border-radius: 5px;
  border-radius: 5px;
  border: 1px solid #6f6222;
#header { background: #ffec50; /* bold yellow */ }
#footer { background: #d0a921; /* darker yellow */ }
.y2k-census {
  position: absolute;
  width: 150px;
  top: 20px;
  right: 20px;
  z-index: 100;
  height: auto;
  background: white;
  padding: 5px;
  -moz-border-radius: 8px;
  -webkit-border-radius: 8px;
  border-radius: 8px;
.y2k-census-close {
  font-weight: bold;
  color: #ff2222;
  cursor: pointer;
  padding: 3px;
  float: right;
  font-size: 1.3em;
KenBuja
MVP Esteemed Contributor
One issue is the function in your app.js contains the argument "dojoOn", but you don't have that module in your require list. However, if you're getting the console message "map is clicked", that must not be a problem in your original code.
Mariagomez1
Hi Ken , really thanks for your advice. the first problem ( that the template does not show ) is solved by adding the  "dojo/on" to app.js file but still i can not see the message in console line. i would appreciate  if anyone can give a advice to solve the second  problem ( a message should appear in console line that " map is clicked" when i click on map).
RobertScheitlin__GISP
Maria,
  The only problems I see are in the app.js. (as you already stated you need the "dojo/on" require, you are using legacy coding style and AMD style, and your parameter for map is "map" and it needs to be "Map"):
require([
    "dojo/parser",
    "dojo/on",
    "dojo/_base/lang",
    "esri/map",
    "y2k/Census",
    "dijit/registry",
    "dojo/dom",
    "dojo/domReady!"
], function(
    parser,
    on,
    lang,
    Map,
    Census,
    ContentPane,
    BorderContainer,
    Button,
    Extent,
    registry,
    dom
    parser.parse();
    var bounds = new Extent({
        "xmin": 817962,
        "ymin": -187036,
        "xmax": 1566109,
        "ymax": 785554,
        "spatialReference": {
            "wkid": 32640
    var map = new Map("map", {
        extent: bounds
        map: map,
KenBuja
And since you aren't using DojoOn in your code, why are you including it (and "dojo/on") in both app.js and Census.js? The "on" functionality is built into the ArcGIS API modules. You should add "dojo/on" if you are using some of its added functionality, such as pausing an event or having it only fire once.
Mariagomez1
Thanks Robert, I changed the app.js according to your codes and all codes moved from legacy to AMD. however, still when i click on map, the "map is clicked" message does not appear in console line.. any idea??
the changed app.js file :
require([
"dojo/parser",
"dojo/on",
"dojo/_base/lang",
"esri/map",
"y2k/Census",
"dijit/registry",
  "dojo/dom",
"dojo/domReady!"
], function(
   parser,
   dojoOn,
   lang,
   Map,
   Census,
   ContentPane,
   BorderContainer,
   Button,
   Extent,
   registry,
   dom
    parser.parse();
        "xmin":817962,
        "ymin":-187036,
        "xmax":1566109,
        "ymax":785554,
        extent: bounds
            map: map,
Mariagomez1
Thank you guys . the problem solved. thank you Ken and Robert.
Maria,
Don't forget to mark this thread as answered.
