Custom Symbology - Limit of 2 attributes
676
03-05-2021 02:53 AM
RonParis
I have a hosted feature service which is being pulled through to JS based map. The feature service is symbolised in AGOL based on an attribute which contains 5 unique values. I am using a custom symbol, of which there are 5 symbols to correspond with the 5 unique values, however when I update values in the feature service, not all custom symbols are showing on the map, instead they disappear. It appears it is only limited to 2.
Is it the case that JS can only visualise 2 custom symbols, or is there a known bug with a workaround?
TIA
