Custom Print code for 3.x
2140
02-23-2022 06:21 AM
Tarunvisvanadula1994
Instead of using existing esri/dijit/print widget from Javascript API 3.x.Do we have any custom code that suites same as default Print Widget.I believe we cant send dynamic attributes using Print widget.Can you pls suggest alternative way of approach for sending Dynamic attributes as inputs to Print service
Thanks in Advance
Note: Not related to WAB Widgets
Noah-Sager
Hi @Tarunvisvanadula1994. What sort of dynamic attributes are you using? Are these additional elements associated with a custom print service?
For 3x, you could try the PrintTask, and see if the PrintParameters.extraParameters can handle the dynamic attributes.
https://developers.arcgis.com/javascript/3/jsapi/printtask-amd.html
https://developers.arcgis.com/javascript/3/jsapi/printparameters-amd.html
For 4x, the Print widget can now handle custom text elements. So if you can update to 4x, this should be available in the UI.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Print.html
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Print.html#templateOption...
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Print-TemplateOptions.htm...
Hi Noah
Thanks for the response, the additional elements are associated with customer print, which will contain logined user information and few other details.
I have my application running over 3x, so I'm planning to have similar print interface what 4x has should be done in 3x.
Can you provide your inputs/suggestions for Achieving 4x print in 3x. That would be great.
Thanks in advance
Noah-Sager
Actually, you might be able to use PrintTemplate.layoutOptions.customTextElements
https://developers.arcgis.com/javascript/3/jsapi/printtemplate-amd.html#layoutoptions
I also found this post which looks relevant for your use case:
https://gis.stackexchange.com/questions/72554/additional-parameters-for-printtask
Hi Noah ,
Thanks for providing info. based on information provided by you im able to create print with following code. But i got struck while sending custom text to print service, i have passed custom text elements(InputType-string) to customTextElements. But in output data is blank. Can you pls check following and let me know if sent anything wrong.
In print service, i have update text format like this <dyn type="text" property="user"/> since im sending string as input. pls correct me if i was wrong
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Custom print</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.39/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        margin: 0;
        padding: 0;
      #demobox {
  background-color:#DFDFDF ;
  box-sizing: border-box;
  padding: 10px ;
  color:#323232;
  line-height: 1.3em;
  border: 1px solid black ;
  position:absolute;
  z-index: 999 !important;
  right: 10px;
    margin-top: 10px;
    width: 300px;
    min-height: 100px;
    max-height: 200px;
    overflow-y: auto;
    display: flex;
    font-family: "Avenir Next","Helvetica Neue",Helvetica,Arial,sans-serif;
.header{
    font-size: 16px;
    font-weight: 600;
    /* padding: 0 0 12px;
    margin: 0 auto 0 0 */
.title_bar{
    background: #78caf4;
    height: 25px;
    width: 100%;
    cursor: pointer;
#widnow{
    width: 300px;
    position: absolute;
    z-index: 9999;
    right: 7px;
    top: 5px;
    border:solid 1px;
    max-height: 350px;
    overflow-y: auto;
.box{
    height: 273px;
    background: #fff;
.esri-input {
    background-color: #fff;
    border: 1px solid rgba(110,110,110,.3);
    color: #323232;
    font-size: 14px;
    width: 100%;
    margin-top: 7px;
    height: 26px;
.Cust_Select{
    cursor: pointer;
    display: block;
    font-family: inherit;
    font-size: .85em;
    width: 190px !important;
    position:absolute;
    height: 32px;
    color: #323232;
    margin: 0;
    -webkit-appearance: none;
    -moz-appearance: none;
    border-radius: 0;
    padding: 0 0.5em;
    background: url("data&colon;image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' viewBox='-8 -8 32 32' width='32' height='32'%3E%3Cpath d='M8 11.207l-4-4V5.793l4 4 4-4v1.414z' fill='%236e6e6e' fillrule='nonzero'/%3E%3C/svg%3E") no-repeat right center #fff;
.Export-button  {
    align-items: center;
    background-color: #0079c1;
    border: 1px solid #0079c1;
    color: #fff;
    cursor: pointer;
    display: flex;
    font-size: 14px;
    min-height: 32px;
    justify-content: center;
    word-break: normal;
    white-space: normal;
    overflow: hidden;
    padding: 6px 7px;
    width: 200px !important;
    transition: background-color 125ms ease-in-out,border 125ms ease-in-out;
    </style>
    <script src="https://js.arcgis.com/3.39/"></script>
    <script>
      var map;
      var templateList=[];
      //$(".box").slideToggle();
      require(["esri/map","esri/tasks/PrintTask","esri/tasks/PrintParameters",
      "esri/request","esri/tasks/PrintTemplate","dojo/_base/array",
      "dojo/domReady!"],
       function(Map,PrintTask,PrintParameters,esriRequest,PrintTemplate,arrayUtils) {
        map = new Map("map", {
          basemap: "streets",  //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
          center: [-122.45, 37.8], // longitude, latitude
          zoom: 9
        var printTask = new PrintTask(PrintService,{
            async:true
        //fetch layout informations from print service
        var printInfo = esriRequest({
          "url": PrintService,
          "content": { "f": "json" }
        $("#layoutDrp").change(function() {
            $(".ExportPanel").empty();
        printInfo.then(function(response){
            console.log(response)
            layoutTemplate = arrayUtils.filter(response.parameters, function(param, idx) {
            return param.name === "Layout_Template";
          var templates = layoutTemplate[0].choiceList
          for (var i = 0; i < templates.length; i++) {
            var option = document.createElement("OPTION");
            option.setAttribute("value", templates[i]);
            var text = document.createTextNode(templates[i]);
            option.appendChild(text);
            document.getElementById("layoutDrp").appendChild(option);
            var P_template = new PrintTemplate();
            P_template.exportOptions = {
                 width: 500,
                 height: 400,
                 dpi: 96
             P_template.layoutOptions={
                 titleText:'', //"Hello World",
                 scalebarUnit:"Miles",
                 legendLayers: []
             P_template.format = "PDF";
             P_template.layout =templates[i]; //"MAP_ONLY";
             P_template.preserveScale = false;
             var obj ={"Temp":P_template,"Name":templates[i]}
             templateList.push(obj);
        console.log(templateList);
        }, function(err){
           console.log(err);
        $("#ExportBtn").click(function(e){
          //alert("hi");
          if($("#layoutDrp").val()==""){
              alert("Please Select layout");
              return;
          $("#ExportBtn").prop('disabled', true);
          $(".ExportPanel").append("<p>Export is Generating.....</p>")
          var Titlename = $("#printTitle").val();
          var selectelayout = $("#layoutDrp").val();
          var params = new PrintParameters();
          var Layout;
          params.map = map;
          params.outSpatialReference = map.spatialReference;
          for (var i = 0; i < templateList.length; i++) {
              if(templateList[i].Name == selectelayout){
                  Layout = templateList[i].Temp;
                  break;
                  //templates[i].layoutOptions.titleText =Titlename;
          Layout.layoutOptions.titleText =Titlename;
          Layout.layoutOptions.customTextElements= [ //Need to define custom attributes
                         { "user": UserName }
          params.template = Layout;
          printTask.execute(params, function(response){
            console.log(response);
            var OutputUrl = response.url;
            var link = $("<a>");
                link.attr("href", OutputUrl);
                link.attr("title", $("#printTitle").val()+".pdf");
                link.text($("#printTitle").val()+".pdf");
                link.attr("target","_blank");
                link.addClass("link");
            // var LiElement = document.createElement("li");
             //LiElement.append(link);
            $(".ExportPanel").append(link);
            $("#ExportBtn").prop('disabled', false);
          },function(error){
              console.log(error);
        function printResult(Result){
            console.log(Result)
        function ErrCallback(err){
            console.log(err)
        $(".title_bar").click(function(){
    </script>
  </head>
  <body>
    <div id="map">
<div id="widnow">
    <div class=" title_bar" title="click to toggle">
        <header class="header-title">Export Information</header>
    </div>
    <div class="box" style="display: none;">
     <div class="" style="margin-top: 20px;margin-left: 10px;position:absolute;">
         <label>Title</label>
         <input type="text" id="printTitle" class="esri-input" placeholder="Enter Print title" />
     </div>
     <div class="" style="margin-top: 95px;margin-left: 10px;position:absolute;">
        <label>Layout</label>
        <select id="layoutDrp" class="Cust_Select">
            <option value="">Choose layout</option>
        </select>
    </div>
    <div style="margin-top: 155px;margin-left: 50px;position:absolute;">
      <button id="ExportBtn" class="Export-button">Export</button>
    </div>
    <div class="print content" style="margin-top: 188px;margin-left: 10px;position:absolute;">
        <hr style="width: 270px !important"/>
        <h6 style="margin-top: 0px;">Exported Files will Appear Below</h6>
       <div class="ExportPanel"></div>
    </div>
    </div>
</div>
    </div>
  </body>
</html>
