Custom labels/values for form template
1494
01-12-2023 07:38 AM
TheGamer
So I'm trying to edit features using feature Form and I was wondering if there is a way to have custom labels/values. So, for instance, if the user selects a specific value for an attribute and then goes to change a value of another attribute, the values should be dependent on the previous selected value
@JoelBennett @Sage_Wall @ReneRubalcava @Anonymous User
JoelBennett
MVP Regular Contributor
I personally haven't implemented this, but support for contingent attributes values within a FeatureForm became available in 4.23.  It appears if you set this up properly in ArcGIS Pro before publishing your service, it will just automatically work in your application.
JoelBennett
