Custom Field Aliases inside Query Widget
1507
09-07-2022 02:43 PM
Rice_GIS
Hello, I'm trying to come up with custom field labels for my query widget in a map I'm creating. I'm using this sample code.
https://developers.arcgis.com/javascript/latest/sample-code/query-related-features/
When the query is run, the fields for the table appears as such:
My aim is to customize the field labels to show cleaner titles like, "City" for "NAME" and "Sum Population" instead of "SUM_POPULATION".
Would anyone know what I need to add and where to add it to achieve this goal?
The entire code for the aforementioned map is here.
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1, maximum-scale=1,user-scalable=no"
    <title>
      Query Related Features | Sample | ArcGIS API for JavaScript 4.24
    </title>
    <style>
      html,
      body {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      #gridDiv {
        padding: 10px;
        max-width: 300px;
      #viewDiv {
        height: 100%;
        width: 100%;
      #clearButton {
        margin-top:5px;
        display: none;
      .dgrid {
        height: auto !important;
      .dgrid .dgrid-scroller {
        position: relative;
        max-height: 200px;
        overflow: auto;
    </style>
    <link rel="stylesheet" href="https://unpkg.com/[email protected]/css/dgrid.css" />
    <script src="https://unpkg.com/[email protected]/"></script>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.24/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.24/"></script>
    <script>
      require([
        "esri/Map",
        "esri/Basemap",
        "esri/views/MapView",
        "esri/layers/FeatureLayer",
        "esri/widgets/Legend",
        "esri/widgets/Expand",
        "dgrid/Grid"
      ], function (Map, Basemap, MapView, FeatureLayer, Legend, Expand, Grid) {
        // Create the layer
        const layer = new FeatureLayer({
          portalItem: {
          outFields: ["*"]
        // Setup the map
        const basemap = new Basemap({
          portalItem: {
        const map = new Map({
          basemap: basemap,
          layers: [layer]
        const view = new MapView({
          container: "viewDiv",
          map: map,
          center: [-98.5795, 39.8282],
          zoom: 3,
          popup: {
            autoOpenEnabled: false
        const legend = new Legend({ view: view });
        // Expand widget to expand and contract the legend widget
        const legendExpand = new Expand({
          expandTooltip: "Show Legend",
          expanded: false,
          view: view,
          content: legend
        // Add widgets to the view
        view.ui.add(document.getElementById("gridDiv"), "bottom-left");
        view.ui.add(legendExpand, "top-right");
        // Initialize variables
        let highlight, grid;
        // call clearMap method when clear is clicked
        const clearbutton = document.getElementById("clearButton");
        clearbutton.addEventListener("click", clearMap);
        layer.load().then(function () {
          return (g = new Grid());
        view.on("click", function (event) {
          clearMap();
          queryFeatures(event);
        function queryFeatures(screenPoint) {
          const point = view.toMap(screenPoint);
          // Query the for the feature ids where the user clicked
          layer
            .queryObjectIds({
              geometry: point,
              spatialRelationship: "intersects",
              returnGeometry: false,
              outFields: ["*"]
            .then(function (objectIds) {
              if (!objectIds.length) {
                return;
              // Highlight the area returned from the first query
              view.whenLayerView(layer).then(function (layerView) {
                if (highlight) {
                  highlight.remove();
                highlight = layerView.highlight(objectIds);
              // Query the for the related features for the features ids found
              return layer.queryRelatedFeatures({
                outFields: ["NAME", "SUM_POPULATION"],
                relationshipId: layer.relationships[0].id,
                objectIds: objectIds
            .then(function (relatedFeatureSetByObjectId) {
              if (!relatedFeatureSetByObjectId) {
                return;
              // Create a grid with the data
              Object.keys(relatedFeatureSetByObjectId).forEach(function (
                objectId
                // get the attributes of the FeatureSet
                const relatedFeatureSet = relatedFeatureSetByObjectId[objectId];
                const rows = relatedFeatureSet.features.map(function (feature) {
                  return feature.attributes;
                if (!rows.length) {
                  return;
                // create a new div for the grid of related features
                // append to queryResults div inside of the gridDiv
                const gridDiv = document.createElement("div");
                const results = document.getElementById("queryResults");
                results.appendChild(gridDiv);
                // destroy current grid if exists
                if (grid) {
                  grid.destroy();
                // create new grid to hold the results of the query
                grid = new Grid(
                    columns: Object.keys(rows[0]).map(function (fieldName) {
                      return {
                        label: fieldName,
                        field: fieldName,
                        sortable: true
                  gridDiv
                // add the data to the grid
                grid.renderArray(rows);
              clearbutton.style.display = "inline";
            .catch(function (error) {
              console.error(error);
        function clearMap() {
          if (highlight) {
            highlight.remove();
          if (grid) {
            grid.destroy();
          clearbutton.style.display = "none";
    </script>
  </head>
  <body>
    <div id="gridDiv" class="esri-widget">
      <h2>US Cities</h2>
      <p>
        Click on a hexagon in the map to view the US cities located in that
        area.
      </p>
      <div id="queryResults"></div>
      <button id="clearButton" class="esri-widget">Clear Query</button>
    </div>
    <div id="viewDiv"></div>
  </body>
</html>
JoelBennett
MVP Regular Contributor
I suppose there are many ways, but here's a simple example.  You would replace lines 181-192 (where the Grid is created) with the following, which uses a simple field name to field alias map:
grid = new Grid(
			var fieldAliases = {
				"NAME": "City",
				"SUM_POPULATION": "Sum Population"
			return {
				label: fieldAliases[fieldName] || fieldName,
				field: fieldName,
				sortable: true
	gridDiv
JoelBennett
grid = new Grid(
				"NAME": "City",
			return {
				field: fieldName,
				sortable: true
	gridDiv
Rice_GIS
Worked Great! Thank you so much!
