Custom buttons
7948
10-01-2019 11:39 AM
GregoryBologna
I am using JS API 4.12. What options are available to create custom buttons with events to a MapView? Do I create a custom widget or use dojo? I'm not sure if this is valid, but I tried using dojo by adding "dijit/form/Button" but the rendered dojo button appears to add a toggle button and other stuff.
RobertScheitlin__GISP
Gregory,
  I think you are looking for something like this:
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Intro to MapView - Create a 2D map - 4.12</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.12/"></script>
    <script>
      require(["esri/Map", "esri/views/MapView"], function(Map, MapView) {
        var map = new Map({
          basemap: "streets"
        var view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 12,
          //padding: 12
          center: [15, 65], // longitude, latitude
          constraints: {
            maxScale: 285
          autoResize: true,
          popup: {
            viewModel: {
              actions: {
                zoom: false
              actionsMenuEnabled: false
            dockEnabled: false,
            dockOptions: {
              breakpoint: false,
            featureNavigationEnabled: true
        var element = document.createElement('div');
        element.className = "esri-icon-collection esri-widget--button esri-widget esri-interactive";
        element.addEventListener('click', function(evt){
          console.log("clicked");
        view.ui.add(element, "top-right");
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
Gregory,
   Can you share your code that displays this issue?
GregoryBologna
Thanks. This may not work out afterall because the map takes longer to load when adding "dijit/form/Button". I am looking into building a widget using React.
add to require
"dijit/form/Button"
          map: map,
          center: [lnglat],
          zoom: 12,
          padding: padding,
          constraints: {
            maxScale: 285
          autoResize: true,
          popup: {
            viewModel: {
              actions: {
                zoom: false
            dockEnabled: false,
            dockOptions: {
              breakpoint: false,
create button
   var button = new Button({
       type: "button",
       iconClass: "esri-icon-collection esri-widget--button esri-widget esri-interactive",
       showLabel: false,
       label: "",
       onClick: function(){
then add to view
view.ui.add(button"top-right");
Gregory,
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
    <script>
        var map = new Map({
          basemap: "streets"
          map: map,
          zoom: 12,
          //padding: 12
          constraints: {
            maxScale: 285
          autoResize: true,
          popup: {
            viewModel: {
              actions: {
                zoom: false
            dockEnabled: false,
            dockOptions: {
              breakpoint: false,
    </script>
  </head>
  <body>
  </body>
</html>
KellyHutchins
Esri Notable Contributor
Robert's reply is correct but a I'd modify the line where you create the element to use document.createElement("button") instead of document.createElement("div").
     var element = document.createElement('button');
The reason for using a button instead of a div since button's have keyboard accessibility built-in by default so you can navigate to the button using the tab keys and activate it using return or enter. This is important when building web sites to ensure they meet accessibility standards (508 and WCAG).
GregoryBologna
This works great. The button element is good. It has that 3d-ish click style. Thank you.
