Cursor offset after adding navigation toolbar
2511
01-21-2017 02:10 PM
NhuMai
I'm having cursor position issues now that I've added a navigation tool bar to my map. This affects not only the window drawn for map zoom, but identifed objects as well.
I've seen this post about popups being in the wrong position, and have attempted to parse before map initialization, but the problem persists. My cursor still traps the wrong position (low and left).
My map and tool bar are created like this (haven't included all modules, but this targets where the issue is) :
Map.js:
var baseMapLayerWorld;
var myLayer;
require([
 "dojo/parser",
 "dojo/on",
 "esri/map",
 "esri/toolbars/navigation",
 "esri/dijit/Search",
 "esri/dijit/Scalebar",
 "dijit/Toolbar",
 "dijit/form/Button",
 "esri/layers/ArcGISTiledMapServiceLayer",
 "esri/layers/ArcGISDynamicMapServiceLayer",
 "esri/layers/FeatureLayer",
 "esri/InfoTemplate",
 "esri/geometry/Extent",
 "dijit/layout/BorderContainer",
 "dijit/layout/ContentPane",
 "dojox/layout/ExpandoPane",
 "dijit/layout/AccordionContainer",
 "dijit/layout/TabContainer",
 "dojo/domReady!"
], function (parser, on, Map, Navigation, Search, Scalebar, Toolbar, Button, ArcGISTiledMapServiceLayer, DynamicMapServiceLayer, FeatureLayer, InfoTemplate, Extent) {
parser.parse();
baseMapLayerWorld = new DynamicMapServiceLayer("http://services.arcgisonline.com/arcgis/rest/services/World_Street_Map/MapServer");
myLayer = new DynamicMapServiceLayer("http://ourserver/arcgis/rest/services/COMMUNE/Public/MapServer");
 var bounds = new Extent({
 "xmin":-17012392,
 "ymin":-2139604,
 "xmax":-16498016,
 "ymax":-1750718,
 "spatialReference":{"wkid":102100}
window.myMap = new Map("map", {
 extent: bounds,
 logo: false
window.myMap.addLayers([baseMapLayerWorld,myLayer]);
var scalebar = new Scalebar({
 map: window.myMap,
 scalebarUnit: "metric",
 attachTo: "top-right",
 scalebarStyle: "line"
dojo.connect(window.myMap, "onExtentChange", showExtent);
var navToolbar;
 navToolbar = new Navigation(window.myMap);
var zoomInButton = new Button({
 label: "test button",
 showLabel: false,
 iconClass: "zoominIcon",
 onClick: function () {
 //alert("test button clicked")
 navToolbar.activate(Navigation.ZOOM_IN);
 }, "zoomin");
 zoomInButton.startup();
var zoomOutButton = new Button({
 showLabel: false,
 iconClass: "zoomoutIcon",
 navToolbar.activate(Navigation.ZOOM_OUT);
 }, "zoomout");
 zoomOutButton.startup();
var zoomFullExtButton = new Button({
 showLabel: false,
 iconClass: "zoomfullextIcon",
navToolbar.zoomToFullExtent();
 }, "zoomfullext");
 zoomFullExtButton.startup();
var zoomPreviousButton = new Button({
 showLabel: false,
 iconClass: "zoomprevIcon",
 navToolbar.zoomToPrevExtent();
 }, "zoomprev");
 zoomPreviousButton.startup();
var zoomNextButton = new Button({
 showLabel: false,
 iconClass: "zoomnextIcon",
 navToolbar.zoomToNextExtent();
 }, "zoomnext");
 zoomNextButton.startup();
var panButton = new Button({
 showLabel: false,
 iconClass: "panIcon",
 navToolbar.activate(Navigation.PAN);
 }, "pan");
 panButton.startup();
var deactivateButton = new Button({
 showLabel: false,
 iconClass: "deactivateIcon",
 navToolbar.deactivate();
 }, "deactivate");
 deactivateButton.startup();
 on(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
window.myMap.on("load", function(){
 require([
 "js/Search",
 "js/Legend",
 "js/Print",
 "js/Identify",
 ], function() {});
function showExtent(extent) {
 var s = "";
 s = "XMin: "+ extent.xmin.toFixed(2) + " "
 +"YMin: " + extent.ymin.toFixed(2) + " "
 +"XMax: " + extent.xmax.toFixed(2) + " "
 +"YMax: " + extent.ymax.toFixed(2);
 //dojo.byId("info").innerHTML = s;
function extentHistoryChangeHandler () {
 // registry.byId("zoomprev").disabled = navToolbar.isFirstExtent();
 // registry.byId("zoomnext").disabled = navToolbar.isLastExtent();
 zoomPreviousButton.disabled = navToolbar.isFirstExtent();
 zoomNextButton.disabled = navToolbar.isLastExtent();
Map and toolbar were added to html page like this:
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="overflow: hidden;width: 100%; height: 100%; margin: 0;">
 <div id="navToolbar" data-dojo-type="dijit/Toolbar" style="background-color:#ffffff;">
 <button type="button" id="zoomin"></button>
 <button type="button" id="zoomout"></button>
 <button type="button" id="zoomfullext"></button>
 <button type="button" id="zoomprev"></button>
 <button type="button" id="zoomnext"></button>
 <button type="button" id="pan"></button>
 <button type="button" id="deactivate"></button>
 </div>
Dojo config like this directly on html page:
 <script>
 var dojoConfig = {
 parseOnLoad: false,
 async: true,
 packages: [
 "location": '/OurApp/agsjs' // for xdomain load
 "location": '/OurApp/js'
 </script>
KenBuja
MVP Esteemed Contributor
You have to use map.reposition() after your map div moves. Take a look at this discussion: https://community.esri.com/thread/43662
NhuMai
Please excuse the formatting of the code below, i can't seem to figure out how to format as code wihin a response..
Makes sense that the offset is due to the addition of the tool bar which had pushed everything down a bit. So, I tried that as well. I'm not sure if I'm putting it in the right place, though.
Both of these haven't worked:
On map load:
require([
"js/Navigate",
"js/Search",
"js/Legend",
"js/Print",
"js/Identify",
], function() {
window.myMap.reposition();
In a separate js/Navigate.js file, after starting up buttons on toolbar:
require([
//"esri/map",
"dojo/on",
//"dojo/parser",
//"dijit/form/Button",
//"dijit/registry",
"dijit/Toolbar",
//"dojo/domReady!"
function (Extent, Navigation, on, Toolbar, Button) {
//parser.parse();
var navToolbar;
// map = new Map("map", {
// basemap: "satellite",
// center: [-56.953, 57.472],
// zoom: 3
showLabel: false,
}, "zoomin");
showLabel: false,
}, "zoomout");
showLabel: false,
}, "zoomfullext");
showLabel: false,
}, "zoomprev");
showLabel: false,
}, "zoomnext");
showLabel: false,
}, "pan");
showLabel: false,
}, "deactivate");
NhuMai
Okay, got it--it has to do with the fact that I stuck the toolbar within the map div
<div class="navBarClass" id="navToolbar" data-dojo-type="dijit/Toolbar" data-dojo-props="region:'top'" style="background-color:#ffffff;">
</div>
