Current Location
948
05-14-2012 11:21 AM
akashmagoon
Could someone implement my code to make it so it points out the users current location. Something similiar to http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/exp_geolocate....
Heres my code
<!doctype html>
<html lang="en">
  <head>
<script language=JavaScript> var message="Please Choose your coordinates!"; function clickIE4(){ if (event.button==2){ alert(message); return false; } } function clickNS4(e){ if (document.layers||document.getElementById&&!document.all){ if (e.which==2||e.which==3){ alert(message); return false; } } } if (document.layers){ document.captureEvents(Event.MOUSEDOWN); document.onmousedown=clickNS4; } else if (document.all&&!document.getElementById){ document.onmousedown=clickIE4; } document.oncontextmenu=new Function("alert(message);return false") </script>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title></title>
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      #map{ margin: 0; padding: 0; }
    </style>
    <script>var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
    <script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      var map;
      function init() {
var initExtent = new esri.geometry.Extent({"xmin":-13114922,"ymin":-5500000,"xmax":9292585,"ymax":10351408, "spatialReference":{"wkid":102100}});
map = new esri.Map("map",{extent:initExtent});
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer");
map.addLayer(basemap);
dojo.connect(map, "onLoad", function() {
  var points = {
   "points": [[-122.63,45.51],[-122.56,45.51],[-122.56,45.55],[-122.62,45.00],[77,19]],
   "spatialReference": ({ "wkid": 4326 })
  var mp = new esri.geometry.Multipoint(points);
  var wm_mp = esri.geometry.geographicToWebMercator(mp);
  var sms = new esri.symbol.SimpleMarkerSymbol();
  var infoTemplate = new esri.InfoTemplate("Bob","Lives in the USA");
  var graphic = new esri.Graphic(wm_mp, sms, '', infoTemplate);
  map.graphics.add(graphic);
  var points = {
   "points": [[85,45.51],[-5,45.51],[45,45.55],[20,45.00],[20,19]],
  var infoTemplate = new esri.InfoTemplate("Jack","Lives in the USA");
  dojo.connect(map.graphics, "onMouseOver", function(evt) {
                  var g = evt.graphic;
                  map.infoWindow.setContent(g.getContent());
                  map.infoWindow.setTitle(g.getTitle());
                  map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint));
               dojo.connect(map.graphics, "onMouseOut", function() {map.infoWindow.hide();} );
dojo.connect(map, "onMouseMove", function(evt) {
      var mp = esri.geometry.webMercatorToGeographic(evt.mapPoint);
      dojo.byId("spanCoords").innerHTML = mp.x + ", " + mp.y;
dojo.byId("spanCoords").innerHTML = (Math.round(mp.x * 10000) / 10000) + ", " + (Math.round(mp.y * 10000) / 10000);
      dojo.ready(init);
    </script>
  </head>
<div style="position: absolute; bottom: 5px; left: 5px; z-index: 8999; padding: 5px; background-color: #ADD8E6;">
    Current Coordinates (Latitude, Longitude): <span id="spanCoords"></span>
</div>
  <body class="tundra">
    <div data-dojo-type="dijit.layout.BorderContainer"
         data-dojo-props="design:'headline',gutters:false"
         style="width: 100%; height: 100%; margin: 0;">
      <div id="map"
           data-dojo-type="dijit.layout.ContentPane"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
