crosshairVisible
970
12-03-2013 12:27 AM
VijaySarin
I am using ArcGIs javascript API "http://js.arcgis.com/3.7/" for my web application.  I want to use something like "crosshairVisible"
property, so that I can highlight the center of the map. Could you please tell me, if there is any option available for ArcGIS javascript  API?
BjornSvensson
Esri Alum
There's no equivalent to the Flex API's Map.crosshairVisible property, but you can just add an image in the middle (on top of the map).
Example: http://jsbin.com/ExUQume/2/edit  - CSS could probably be improved but it would get you a starting point...
VijaySarin
Thanks Bjorn Svensson. That works.
