CREDITS & DATE OF AERIAL
4421
02-11-2015 05:21 AM
ChuckTurlington
Hello,
I am using Esri ArcMap 10.2.1.
I need to qualify an aerial image in my notes on a figure.  I recognize the aerial stamp (credits) at the bottom of the figure but it does not contain a date the aerial was last updated.  Is it possible to find the date of the aerials that get downloaded from the Add Basemap button in ArcMap?
TimWitt2
Chuck,
I have created a tool that can tell you that, check it out here:
http://jsfiddle.net/timw1984/39pa1q8a/embedded/result/
Just zoom to where you need the date and click on the map.
And here is the blog post in case you need the code: Javascript API - Aerial Information Widget
Hope this helps!
Tim
TimWitt2
Chuck,
Hope this helps!
Tim
