Creating a Popup Window
3335
10
01-02-2018 11:18 AM
deleted-user-2LRxCQRqNecK
I'm having trouble getting a popup window to show any information. When I click on the map it pops up, but has no information. I've tried everything and researched for days now on the topic. Any help would be appreciated.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <title>Future Land Use Map</title>
   <link rel="stylesheet" type="text/css" href="https://gis.fwb.org/arcgis_js_api/library/3.23/3.23/dijit/themes/claro/claro.css"/>
   <link rel="stylesheet" type="text/css" href="https://gis.fwb.org/arcgis_js_api/library/3.23/3.23/esri/css/esri.css"/>
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
      #mapPane {
    /*margin-left: 300px;*/
         padding: 0;
         border-left: solid 2px #224a54;
         background-color: #FFFFFF;
         height: 100%; width: 100%;
      #rightPane {
      width: 20%;
    #legendPane {
      border: solid #97DCF2 1px;
    #opacitySliderDiv {
         display: block;
         position: absolute;
         z-index: 2;
         bottom: 20px;
         left: 74px;
   </style>
   <script type="text/javascript">
               var dojoConfig = {
                    async : false,
                    mblHideAddressBar : false,
                    packages : [{
                         location : location.pathname.replace(/\/[^/]+$/, '') + '/js'
     </script>
    <script src="https://gis.fwb.org/arcgis_js_api/library/3.23/3.23/"></script>
      <script type="text/javascript" src="js/lods_extent.js"></script>
      <script type="text/javascript" src="js/IdentifyAll.js"></script>
     <script>
          var map;
          var initExtent;
          var lods = [];
          var spatialReference;
      require([
          "esri/urlUtils",
        "esri/SpatialReference",
        "esri/map",
        "esri/dijit/Search",
        "esri/basemaps",
        "esri/dijit/BasemapLayer",
        "esri/dijit/Basemap",
        "esri/dijit/BasemapGallery",
        "esri/arcgis/utils",
        "esri/geometry/Extent",
        "esri/tasks/GeometryService",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/config",
        "esri/dijit/Legend",
        "esri/InfoWindowBase",
        "esri/InfoTemplate",
        "esri/dijit/Popup",
        "esri/dijit/PopupTemplate",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/tasks/IdentifyTask",
        "esri/tasks/IdentifyParameters",
        "esri/Color",
        "dojo/string",
        "esri/domUtils",
        "dojo/dom",
        "dojo/dom-style",
        "dojo/dom-construct",
        "dojo/on",
        "dojo/parser",
        "dijit/layout/AccordionContainer",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dijit/TitlePane",
        "dojo/_base/array",
        "dojo/domReady!",
      ], function (urlUtils, SpatialReference, Map, Search, esriBasemaps, BasemapLayer, Basemap, BasemapGallery, arcgisUtils, SpatialReference, Extent, GeometryService, ArcGISDynamicMapServiceLayer, esriConfig, Legend, InfoWindowBase, InfoTemplate, Popup, PopupTemplate, SimpleFillSymbol, SimpleLineSymbol, IdentifyTask, IdentifyParameters, Color, string, domUtils, dom, domStyle, domConstruct, on, parser, array) {
            parser.parse();
          //Geometry Service
          esriConfig.defaults.geometryService = new GeometryService("https://gis.fwb.org/arcgis/rest/services/Utilities/Geometry/GeometryServer");
          //esri.config.defaults.io.corsEnabledServers.push("https://gis.fwb.org");
          esriConfig.defaults.io.proxyUrl = "https://gis.fwb.org/proxy/proxy.ashx";
          esriConfig.defaults.io.alwaysUseProxy = false;
          esriConfig.defaults.io.corsDetection = false;
          urlUtils.addProxyRule({
              urlPrefix: "route.arcgis.com",
              proxyUrl: "https://gis.fwb.org/proxy/proxy.ashx"
              urlPrefix: "traffic.arcgis.com",
              urlPrefix: "logistics.arcgis.com",
          spatialReference = new SpatialReference({
               wkid : 102100
          setLods();
          setExts();
            var legendLayers = [];
            var basemaps = [];
            var identifyTask;
            var identifyParams;
            var popup = new Popup({
                 fillSymbol:
                 new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
            new Color([255, 0, 0]), 2),
            new Color([255, 255, 0, 0.25]))
        }, domConstruct.create("div"));
            var map = new Map("map", {
             extent: initExtent,
               lods: lods,
               map: aerielLayer,
               infoWindow: popup
          map.on("load", mapReady);
            var aerielLayer = new BasemapLayer({
              url: "https://gis.fwb.org/arcgis/rest/services/Maps/AerialFeb2016WebM/MapServer"
          var aerielBasemap = new Basemap({
              layers: [aerielLayer],
              title:"2016 Aeriel",
              thumbnailUrl:"Images/basemap_streets.jpg"
            basemaps.push(aerielBasemap);
            var basemapGallery = new BasemapGallery({
                 showArcGISBasemaps: false,
                 basemaps: basemaps,
              map: map
            }, "basemapGalleryDiv");
        var search = new Search({
            map: map
         }, "search");
        search.startup();
        var fluURL = "https://gis.fwb.org/arcgis/rest/services/Maps/FLU/MapServer";
        var selectionHandler = dojo.connect(basemapGallery,"onSelectionChange",function(){
          dojo.disconnect(selectionHandler);
             var addressLayer = new ArcGISDynamicMapServiceLayer("https://gis.fwb.org/arcgis/rest/services/Maps/Addresses/MapServer", {
                    visible : true,
               var parcelsAR = new ArcGISDynamicMapServiceLayer("https://gis.fwb.org/arcgis/rest/services/Maps/ParcelsAerial/MapServer", {
                    visible : true,
               var roadNames = new ArcGISDynamicMapServiceLayer("https://gis.fwb.org/arcgis/rest/services/Maps/RoadNames/MapServer", {
                    visible : true,
               var cityLimits = new ArcGISDynamicMapServiceLayer("https://gis.fwb.org/arcgis/rest/services/Maps/CityLimits/MapServer", {
                    visible : true,
               var flu = new ArcGISDynamicMapServiceLayer(fluURL, {
                    visible : true,
                    outFields: ["Zoning"],
                    opacity: 0.5
        map.on("layers-add-result", function () {
        var legend = new Legend({
            map: map,
            layerInfos: legendLayers
          }, "legendDiv");
          legend.startup();
          legendLayers.push({layer: flu, title: "Future Land Use"});
            map.addLayers([parcelsAR, flu, cityLimits, roadNames, addressLayer]);
          basemapGallery.startup();
          function mapReady () {
          map.on("click", executeIdentifyTask);
          //create identify tasks and setup parameters
          identifyTask = new IdentifyTask("flu");
          identifyParams = new IdentifyParameters();
          identifyParams.tolerance = 3;
          identifyParams.returnGeometry = true;
          identifyParams.layerIds = [0];
          identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE;
          identifyParams.width = map.width;
          identifyParams.height = map.height;
        function executeIdentifyTask (event) {
          identifyParams.geometry = event.mapPoint;
          identifyParams.mapExtent = map.extent;
          var deferred = identifyTask
            .execute(identifyParams)
            .addCallback(function (response) {
              // response is an array of identify result objects
              // Let's return an array of features.
              return arrayUtils.map(response, function (result) {
                var feature = result.feature;
                   var layerName = result.layerName;
                feature.attributes.layerName = layerName;
                    if (layerName === 'FUTURE LAND USE') {
                  var zoningTemplate = new InfoTemplate("Zoning: ${Zoning}");
                  feature.setInfoTemplate(zoningTemplate);
                else if (layerName === 'FUTURE LAND USE') {
                  console.log(feature.attributes.Addresses);
                  var addressTemplate = new InfoTemplate("",
                    "Address: ${Addresses}");
                  feature.setInfoTemplate(addressTemplate);
                return feature;
          // InfoWindow expects an array of features from each deferred
          // object that you pass. If the response from the task execution
          // above is not an array of features, then you need to add a callback
          // like the one above to post-process the response and return an
          // array of features.
          map.infoWindow.setFeatures([deferred]);
          map.infoWindow.show(event.mapPoint);
   </script>
</head>
<body class="claro">
     <div id="search"></div>
     <div data-dojo-type="dijit/layout/BorderContainer"
             data-dojo-props="design:'headline', gutters:false"
             style="width:100%;height:100%;margin:0;">
      <div id="map"
          data-dojo-type="dijit/layout/ContentPane"
        data-dojo-props="region:'center'"
        style="padding:0;">
      </div>
      <div id="rightPane"
       data-dojo-props="region:'right'">
    <div data-dojo-type="dijit/layout/AccordionContainer">
      <div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
           data-dojo-props="title:'Legend', selected:true">
        <div id="legendDiv"></div>
      </div>
    </div>
    <div id="mapDiv"></div>
    </div>
</body>
</html>
RobertScheitlin__GISP
Jeremy,
  I have it displaying info in the popup. Here is what I have:
<!DOCTYPE html>
<html>
<head>
  <link rel="stylesheet" type="text/css" href="https://gis.fwb.org/arcgis_js_api/library/3.23/3.23/dijit/themes/claro/claro.css" />
  <link rel="stylesheet" type="text/css" href="https://gis.fwb.org/arcgis_js_api/library/3.23/3.23/esri/css/esri.css" />
  <style>
    html,
    body,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #search {
      display: block;
      position: absolute;
      z-index: 2;
      top: 20px;
      left: 74px;
    #mapPane {
      padding: 0;
      height: 100%;
      width: 100%;
    #rightPane {
      width: 20%;
    #legendPane {
    #opacitySliderDiv {
      display: block;
      position: absolute;
      z-index: 2;
      bottom: 20px;
      left: 74px;
  </style>
    var dojoConfig = {
      async: false,
      mblHideAddressBar: false,
      packages: [{
        location: location.pathname.replace(/\/[^/]+$/, '') + '/js'
  </script>
  <!-- <script type="text/javascript" src="js/IdentifyAll.js"></script> -->
  <script>
    var map;
    var initExtent;
    var lods = [];
    require([
      "esri/urlUtils",
      "esri/map",
      "esri/basemaps",
      "esri/config",
      "esri/dijit/Popup",
      "esri/Color",
      "dojo/string",
      "esri/domUtils",
      "dojo/dom",
      "dojo/dom-style",
      "dojo/on",
      "dojo/parser",
      "dojo/_base/array",
      "dijit/TitlePane",
      "dojo/domReady!",
    ], function(
      parser, arrayUtils) {
      parser.parse();
      //Geometry Service
        wkid: 102100
      setLods();
      setExts();
      var basemaps = [];
      var identifyTask;
      var identifyParams;
        fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
        extent: initExtent,
        lods: lods,
        map: aerielLayer,
        infoWindow: popup
        title: "2016 Aeriel",
        thumbnailUrl: "Images/basemap_streets.jpg"
        basemaps: basemaps,
        map: map
        map: map
      }, "search");
      search.startup();
      var selectionHandler = dojo.connect(basemapGallery, "onSelectionChange", function() {
          visible: true,
          visible: true,
          visible: true,
          visible: true,
          visible: true,
          opacity: 0.5
        map.on("layers-add-result", function() {
            map: map,
          }, "legendDiv");
          legend.startup();
        legendLayers.push({
          layer: flu,
      function mapReady() {
        identifyTask = new IdentifyTask(fluURL);
      function executeIdentifyTask(event) {
          .addCallback(function(response) {
            return arrayUtils.map(response, function(result) {
              // } else if (layerName === 'FUTURE LAND USE') {
              //   console.log(feature.attributes.Addresses);
              //   var addressTemplate = new InfoTemplate("",
              //     "Address: ${Addresses}");
              //   feature.setInfoTemplate(addressTemplate);
              return feature;
  </script>
</head>
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;margin:0;">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="padding:0;">
    </div>
    <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
        <div data-dojo-type="dijit/layout/ContentPane" id="legendPane" data-dojo-props="title:'Legend', selected:true">
        </div>
      </div>
    </div>
</body>
</html>
Jeremy,
  Your if else if statement seems to be evaluating the same condition...
Ok, I changed that and it is still not working.
Jeremy,
   I could help you debug this further if I had
lods_extent.js
IdentifyAll.js
This is IdentifyAll.js:
var identifyTask;
function initIdentifies(map) {
     idParams.tolerance = 6;
     idParams.returnGeometry = true;
     //idParams.maxAllowableOffset = 2;
     idParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
function runIdentifies(evt) {
     require(["dojo/promise/all"], function(All){
     editToolbar.deactivate();
     var measureMode = dojo.query(".esriButton .dijitButtonNode").some(function(node, index, arr) {
          if (node.childNodes[0].checked) {
               //at least one of the measure tools is active so disable identify
               return true;
     if (!measureMode) {
          //addIdentMaps is at the bottom of this page and pushes only the visible layers that we want to tasks array
          addIdentMaps();
          //check for map visibility and add identify task to pertinent sublayers
          defTasks = dojo.map(tasks, function(task) {
               return new dojo.Deferred();
          //map each identify task to a new dojo.Deferred
          dlTasks = new dojo.DeferredList(defTasks);
          //And use all of these Deferreds in a DeferredList
          dlTasks.then(showResults);
          //chain showResults onto your DeferredList
          idParams.width = map.width;
          idParams.height = map.height;
          idParams.geometry = evt.mapPoint;
          idParams.mapExtent = map.extent;
          for ( i = 0; i < tasks.length; i++) {//Use 'for' instead of 'for...in' so you can sync tasks with defTasks
               try {
                    tasks.execute(idParams, defTasks.callback, defTasks.errback);
                    //Execute each task
               } catch (e) {
                    console.log("Error caught");
                    console.log(e);
                    defTasks.errback(e);
                    //If you get an error for any task, execute the errback
function showResults(r) {
     require(["esri/dijit/PopupTemplate"], function (PopupTemplate) {
     var resultsid = [];
     r = dojo.filter(r, function(result) {
          return r[0];
     //filter out any failed tasks
     for ( i = 0; i < r.length; i++) {
          resultsid = resultsid.concat(r[1]);
     resultsid = dojo.map(resultsid, function(result) {
          feature.attributes.layerName = result.layerName; {
               if (result.layerName == "City Addresses") {
                    var template = new PopupTemplate({
                         title : "Official City Address",
                         fieldInfos : [{
                              fieldName : "SITE_ADDR",
                              visible : true,
                              label : "Official City Address:"
                              fieldName : "LOCID",
                              visible : true,
                              label : "Location ID:"
                              fieldName : "Hyperlink",
                              visible : false,
                              label : "Hyperlink:"
                         mediaInfos : [{
                              "title" : "",
                              "caption" : "",
                              "type" : "image",
                              "value" : {
                                   "sourceURL" : "images/Hyperlink5.png",
                                   "linkURL": "{HyperlinkB}"
               } else if (result.layerName == "County Addresses") {
                         title : "County Address",
                         fieldInfos : [{
                              visible : true,
                              label : "County Address:"
                              fieldName : "X_COORD",
                              visible : true,
                              label : "XCoord:"
                              fieldName : "Y_COORD",
                              visible : true,
                              label : "YCoord:"
                              fieldName : "ESN_EMS",
                              visible : true,
                              label : "EMS:"
                              fieldName : "ESN_FIRE",
                              visible : true,
                              label : "FIRE:"
                              fieldName : "PIN",
                              visible : true,
                              label : "PIN:"
               } else if (result.layerName == "CDBG Boundary") {
                         title : "CDBG Boundary",
                         fieldInfos : [{
                              fieldName : "geoname",
                              visible : true,
                              label : "Description:"
                              fieldName : "lowmod_pct100",
                              visible : true,
                              label : "Low/Moderate %:"
                              fieldName : "GEOID",
                              visible : true,
                              label : "GEOID:"
               } else if (result.layerName == "FDOT Milepost") {
                         title : "FDOT Milepost",
                         fieldInfos : [{
                              fieldName : "ROADWAY",
                              visible : true,
                              label : "ROADWAY:"
                              fieldName : "intsec_des",
                              visible : true,
                              label : "Intersection Description:"
                              fieldName : "BEGIN_POST",
                              visible : true,
                              label : "Begin Milepost:"
               } else if (result.layerName == "Parcels") {
                         title : "Parcel",
                         fieldInfos : [{
                              fieldName : "PIN",
                              visible : true,
                              label : "PARCEL PIN:"
                              fieldName : "OWNER_NAME",
                              visible : true,
                              label : "Owner Name:"
                              fieldName : "ADDRESS_1",
                              visible : true,
                              label : "Owner Address1:"
                              fieldName : "ADDRESS_2",
                              visible : true,
                              label : "Owner Address2:"
                              fieldName : "ADDRESS_3",
                              visible : true,
                              label : "Owner Address3:"
                              fieldName : "CITY_NAME",
                              visible : true,
                              label : "City:"
                              fieldName : "ST",
                              visible : true,
                              label : "State:"
                              fieldName : "ZIPCODE",
                              visible : true,
                              label : "Zip Code:"
                              fieldName : "USEDESC",
                              visible : true,
                              label : "Use Description:"
                              fieldName : "SALEDT1",
                              visible : true,
                              label : "Latest Sale Date:"
                              fieldName : "SALEADJ1",
                              visible : true,
                              label : "Latest Sale Price:"
                              fieldName : "B_AYB",
                              visible : true,
                              label : "Building Year Built:"
                              fieldName : "GIS_ACRE",
                              visible : true,
                              label : "GIS Parcel Acreage:"
                              fieldName : "LEGL1",
                              visible : true,
                              label : "Legal Description:"
                              fieldName : "LEGL2",
                              visible : true,
                              label : "Legal Description Cont'd:"
                              fieldName : "LEGL3",
                              visible : true,
                         mediaInfos : [{
                              "title" : "",
                              "caption" : "",
                              "type" : "image",
                              "value" : {
                                   "sourceURL" : "images/OCPropAppSeal.png",
                                   "linkURL" : "http://qpublic6.qpublic.net/fl_display_dw.php?county=fl_okaloosa&KEY={PIN}"
               } else if (result.layerName == "ROW Projects") {
                         title : "ROW Construction Project",
                         fieldInfos : [{
                              fieldName : "ProjectNumber",
                              visible : true,
                              label : "Project Number:"
                              fieldName : "ProjectDescription",
                              visible : true,
                              label : "Project Description:"
                              visible : false,
                         mediaInfos : [{
                              "title" : "",
                              "caption" : "",
                              "type" : "image",
                              "value" : {
                                   "linkURL": "file://///FWBGIS\\projects\\{Hyperlink}"
               } else if (result.layerName == "DEEDS") {
                         title : "Deed",
                         fieldInfos : [{
                              fieldName : "DocNum",
                              visible : true,
                              label : "Deed Number:"
                              fieldName : "DocNumDate",
                              visible : true,
                              label : "Deed Date:"
                         mediaInfos : [{
                              "title" : "{HyperlinkA}",
                              "caption" : "",
                              "type" : "image",
                              "value" : {
                                   "sourceURL" : "images/Hyperlink.png",
                                   "linkURL" : "http://fwbgis/Documents/{HyperlinkA}"
               } else if (result.layerName == "ANNEXATION ORDINANCE") {
                         title : "Annexation Ordinance",
                         fieldInfos : [{
                              visible : true,
                              label : "Annexation Ordinance Number:"
                              visible : true,
                              label : "Ordinance Date:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "ORDINANCES") {
                         title : "Ordinance",
                         fieldInfos : [{
                              visible : true,
                              label : "Ordinance Number:"
                              visible : true,
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "RESOLUTIONS") {
                         title : "Resolution",
                         fieldInfos : [{
                              visible : true,
                              label : "Resolution Number:"
                              visible : true,
                              label : "Resolution Date:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "EASEMENT_DISCLAIMED") {
                         title : "Easement Disclaimer",
                         fieldInfos : [{
                              fieldName : "DocNumber",
                              visible : true,
                              label : "Disclaimer Easement Number:"
                              visible : true,
                              label : "Disclaimer Date:"
                              fieldName : "EasementType",
                              visible: true,
                              label : "Disclaimer Type:"
                              fieldName : "Comments",
                              visible : true,
                              label : "Comments:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "EASEMENT_Deed") {
                         title : "Deed Easement",
                         fieldInfos : [{
                              visible : true,
                              label : "Deed Easement Number:"
                              visible : true,
                              visible: true,
                              label : "Easement Type:"
                              visible : true,
                              label : "Comments:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "EASEMENT_Ordinance") {
                         title : "Ordinance Easement",
                         fieldInfos : [{
                              visible : true,
                              label : "Ordinance Easement Number:"
                              visible : true,
                              visible: true,
                              visible : true,
                              label : "Comments:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "EASEMENT_Plat") {
                         title : "Plat Easement",
                         fieldInfos : [{
                              visible : true,
                              label : "Plat Easement Number:"
                              visible : true,
                              label : "Plat Date:"
                              visible: true,
                              visible : true,
                              label : "Comments:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "EASEMENT") {
                         title : "Easement",
                         fieldInfos : [{
                              visible : true,
                              label : "Easement Number:"
                              visible : true,
                              label : "Easement Date:"
                              visible: true,
                              visible : true,
                              label : "Comments:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "EASEMENT_RCovenants") {
                         title : "Restrictive Covenants Easement",
                         fieldInfos : [{
                              visible : true,
                              label : "R/C Easement Number:"
                              visible : true,
                              label : "R/C Date:"
                              visible: true,
                              visible : true,
                              label : "Comments:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "Brownfield Areas") {
                         title : "Brownfield Area",
                         fieldInfos : [{
                              fieldName : "Name",
                              visible : true,
                              label : "Brownfield Area:"
                              fieldName : "SHAPE.area",
                              visible : true,
                              label : "Shape Area:"
               } else if (result.layerName == "Municipal Boundary") {
                         title : "Municipal Boundary",
                         fieldInfos : [{
                              fieldName : "CITY_CODE",
                              visible : true,
                              label : "Municipal Name:"
               } else if (result.layerName == "CityProperty") {
                         title : "City Property",
                         fieldInfos : [{
                              fieldName : "IDENTIFYING_NAME",
                              visible : true,
                              label : "City Property:"
                              fieldName : "Parcel__",
                              visible : true,
                              label : "City Parcel Number:"
                              fieldName : "PARCEL_LETTER",
                              visible : true,
                              label : "City Parcel Letter:"
                              fieldName : "USE_",
                              visible : true,
                              label : "Use:"
                              fieldName : "AREA",
                              visible : true,
                              label : "AREA:"
                              fieldName : "UNITS_FOR_AREA",
                              visible : true,
                              label : "UNITS OF MEASURE:"
                              fieldName : "PARKS",
                              visible : true,
                              label : "Park Type:"
                              fieldName : "OWNER",
                              visible : true,
                              label : "Owner:"
                              fieldName : "ADDRESS__",
                              visible : true,
                              label : "Address Number:"
                              fieldName : "ADDRESS_STREET",
                              visible : true,
                              label : "Street:"
                              fieldName : "ADDRESS_QUAD",
                              visible : true,
                              label : "Quadrant:"
                              fieldName : "COMMENTS",
                              visible : true,
                              label : "Comments:"
                              fieldName : "DEED_RESTRICTIONS",
                              visible : true,
                              label : "Deed Restrictions:"
                              fieldName : "DEED__1",
                              visible : true,
                              label : "Deed1:"
                              fieldName : "DEED_2",
                              visible : true,
                              label : "Deed2:"
                              fieldName : "DEED__3",
                              visible : true,
                              label : "Deed3:"
                              fieldName : "DEED__4",
                              visible : true,
                              label : "Deed4:"
                              fieldName : "DEED__5",
                              visible : true,
                              label : "Deed5:"
                              fieldName : "DEED__6",
                              visible : true,
                              label : "Deed6:"
                              fieldName : "DEED__7",
                              visible : true,
                              label : "Deed7:"
               } else if (result.layerName == "Fire Stations") {
                         title : "Fire Station",
                         fieldInfos : [{
                              fieldName : "Station_no",
                              visible : true,
                              label : "Fire Station No.:"
                              fieldName : "USNG",
                              visible : true,
                              label : "USNG:"
                              fieldName : "LAT",
                              visible : true,
                              label : "Latitude:"
                              fieldName : "LON",
                              visible : true,
                              label : "Longitude:"
                              fieldName : "Dept",
                              visible : true,
                              label : "Department:"
               } else if (result.layerName == "FIRM") {
                         title : "Flood Zone",
                         fieldInfos : [{
                              fieldName : "FLD_ZONE",
                              visible : true,
                              label : "Flood Insurance Rate Map Zone:"
                              fieldName : "STATIC_BFE",
                              visible : true,
                              label : "Static BFE:"
               } else if (result.layerName == "FIRM2016") {
                         fieldInfos : [{
                              visible : true,
                              label : "Proposed Flood Insurance Rate Map Zone:"
                              visible : true,
               } else if (result.layerName == "Code Enforcement") {
                         title : "Code Enforcement Zone",
                         fieldInfos : [{
                              fieldName : "CodeOfficer",
                              visible : true,
                              label : "Code Enforcement Officer:"
               } else if (result.layerName == "EXISTING LAND USE") {
                         title : "Existing Land Use",
                         fieldInfos : [{
                              fieldName : "ELU_Desc",
                              visible : true,
                              label : "Existing Land Use:"
                              fieldName : "Zoning_Desc",
                              visible : true,
                              label : "Zoning:"
                              fieldName : "FLU_Desc",
                              visible : true,
                              label : "Future Land Use:"
                              fieldName : "Zoning_Hyperlink",
                              visible : true,
                              label : "Zoning Hyperlink:"
                              fieldName : "FLU_Hyperlink",
                              visible : true,
                              label : "Future Land Use Hyperlink:"
               } else if (result.layerName == "ZONING") {
                         title : "Zoning",
                         fieldInfos : [{
                              visible : true,
                              label : "Zoning:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
               } else if (result.layerName == "FUTURE LAND USE") {
                         title : "Future Land Use",
                         fieldInfos : [{
                              visible : true,
                              visible : true,
                              label : "Zoning:"
                              visible : true,
                              visible : true,
                              visible : true,
               } else if (result.layerName == "Yard Waste") {
                         title : "Residential Yard Waste",
                         fieldInfos : [{
                              fieldName : "YARD_WASTE_DAY",
                              visible : true,
                              label : "Day of Week:"
                              fieldName : "ROUTE",
                              visible : true,
                              label : "Route:"
               } else if (result.layerName == "Garbage") {
                         title : "Residential Garbage",
                         fieldInfos : [{
                              fieldName : "DAY_OF_WEEK",
                              visible : true,
                              fieldName : "Route",
                              visible : true,
                              label : "Route:"
               } else if (result.layerName == "Recycling") {
                         title : "Residential Recycling",
                         fieldInfos : [{
                              visible : true,
                              visible : true,
                              label : "Route:"
               } else if (result.layerName == "Recycling Drop Off Locations") {
                         title : "Recycling Drop Off Locations",
                         fieldInfos : [{
                              fieldName : "LOCATION",
                              visible : true,
                              label : "Location:"
                              fieldName : "ADDRESS",
                              visible : true,
                              label : "Address:"
               } else if (result.layerName == "Predicted Surge") {
                         title : "Predicted Surge",
                         fieldInfos : [{
                              fieldName : "Cat",
                              visible : true,
                              label : "Predicted Surge - Hurricane Category:"
               } else if (result.layerName == "ElevCert_poly") {
                         title : "Elevation Certificate",
                         fieldInfos : [{
                              fieldName : "Address_No",
                              visible : true,
                              fieldName : "Street",
                              visible : true,
                              label : "Street Name:"
                              fieldName : "Street_Type",
                              visible : true,
                              label : "Street Type:"
                              fieldName : "Street Direction",
                              visible : true,
                              label : "Street Direction:"
                         mediaInfos : [{
                              "title" : "{Hyperlink}",
                              "caption" : "",
                              "type" : "image",
                              "value" : {
                                   "linkURL" : "{Hyperlink}"
               } else if (result.layerName == "Parks") {
                         title : "Park",
                         fieldInfos : [{
                              fieldName : "Name of Facility",
                              visible : true,
                              label : "Park Name:"
                              fieldName : "Address",
                              visible : true,
                              label : "Address:"
               } else if (result.layerName == "Neighborhoods") {
                         title : "Neighborhood",
                         fieldInfos : [{
                              fieldName : "Neighborhood_Name",
                              visible : true,
                              label : "Neighborhood:"
               } else if (result.layerName == "Jan2017Wetlands") {
                         title : "National Wetland Inventory",
                         fieldInfos : [{
                              fieldName : "WETLAND_TYPE",
                              visible : true,
                              label : "Wetland Type:"
               } else if (result.layerName == "Soil") {
                         title : "NRCS/USDA Soil Inventory",
                         fieldInfos : [{
                              fieldName : "MUSYM",
                              visible : true,
                              label : "Soil Number:"
                              fieldName : "MUKEY",
                              visible : true,
                              label : "Soil Key:"
                              fieldName : "muname",
                              visible : true,
                              label : "Soil Description:"
               } else if (result.layerName == "PCI") {
                         title : "Pavement Condition Index",
                         fieldInfos : [{
                              fieldName : "PCI",
                              visible : true,
                              label : "Pavement Condition Index:"
                              fieldName : "Name",
                              visible : true,
                              label : "Branch Name:"
                              fieldName : "SectionID",
                              visible : true,
                              label : "Section ID:"
                              fieldName : "FROM",
                              visible : true,
                              label : "From Intersection:"
                              fieldName : "To",
                              visible : true,
                              label : "To Intersection:"
                              fieldName : "Length",
                              visible : true,
                              label : "Length:"
                              fieldName : "Width",
                              visible : true,
                              label : "Width:"
                              fieldName : "LSTNSPCTND",
                              visible : true,
                              label : "Last Date of Inspection:"
                              fieldName : "LSTLCLMJRW",
                              visible : true,
                              label : "Last Date of Paving:"
               } else if (result.layerName == "SSReferenceBoundary") {
                         title : "Sewer Reference",
                         fieldInfos : [{
                              fieldName : "RefNumber",
                              visible : true,
                              label : "Sewer Reference No.:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "WReferenceBoundary") {
                         title : "Water Reference",
                         fieldInfos : [{
                              visible : true,
                              label : "Water Reference No.:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "SewerTapFees") {
                         title : "Sewer Tap",
                         fieldInfos : [{
                              fieldName : "RcptNumber",
                              visible : true,
                              label : "Sewer Tap Receipt No.:"
                              fieldName : "RcptDate",
                              visible : true,
                              label : "Receipt Date:"
                              visible : true,
                              visible : true,
                              label : "Comments:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "WaterTapFees") {
                         title : "Water Tap",
                         fieldInfos : [{
                              visible : true,
                              label : "Water Tap Receipt No.:"
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Comments:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "Subdivisions Boundaries") {
                         title : "Subdivision",
                         fieldInfos : [{
                              fieldName : "Name",
                              visible : true,
                              label : "Subdivision:"
                         mediaInfos : [{
                              "caption" : "",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "Lots") {
                         title : "Sudivision Lot",
                         fieldInfos : [{
                              fieldName : "LOT_NO",
                              visible : true,
                              label : "Subdivision Lot No:"
               } else if (result.layerName == "StreetSigns") {
                         title : "Street Sign",
                         fieldInfos : [{
                              fieldName : "Subtype",
                              visible : true,
                              label : "Street Sign:"
                              fieldName : "Date_",
                              visible : true,
                              label : "Install Date:"
                              fieldName : "MaintainedBy",
                              visible : true,
                              label : "Maintained By:"
                              fieldName : "Speed",
                              visible : true,
                              label : "Speed Limit:"
               } else if (result.layerName == "StreetLights_point") {
                    var objnm = result.OBJNAME;
                    var locdes = result.LocationDescription;
                         title : "Street Light",
                         fieldInfos : [{
                              fieldName : "Light_Type",
                              visible : true,
                              label : "Light Type:"
                              fieldName : "Intensity",
                              visible : true,
                              label : "Intensity:"
                              fieldName : "Date_Installed",
                              visible : true,
                              label : "Date Installed:"
                              fieldName : "OBJNAME",
                              visible : true,
                              label : "Light ID:"
                              fieldName : "GP_Pole_No",
                              visible : true,
                              label : "GP Pole No:"
                              fieldName : "LocationDescription",
                              visible : true,
                              label : "Location Description:"
                              fieldName : "Account",
                              visible : true,
                              label : "Account:"
                              fieldName : "Owner",
                              visible : true,
                              label : "Owner:"
                              fieldName : "Verified_Intensity",
                              visible : true,
                              label : "Verified Intensity:"
                              fieldName : "Verified_Location",
                              visible : true,
                              label : "Verified Location:"
                              fieldName : "Streetscape",
                              visible : true,
                              label : "Streetscape:"
                              fieldName : "Neighborhood",
                              visible : true,
                              fieldName : "CRA",
                              visible : true,
                              label : "CRA:"
                              fieldName : "FDOT",
                              visible : true,
                              label : "FDOT:"
                              fieldName : "State_Road_Num",
                              visible : true,
                              label : "State Road No.:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "ssCleanOut") {
                         title : "SS Cleanout",
                         fieldInfos : [{
                              visible : true,
                              label : "Cleanout Location:"
                              fieldName : "AsbuiltNumber",
                              visible : true,
                              label : "Project No:"
                              fieldName : "InstallDate",
                              visible : true,
                              fieldName : "Easting",
                              visible : true,
                              label : "Easting:"
                              fieldName : "Northing",
                              visible : true,
                              label : "Northing:"
                              fieldName : "Height",
                              visible : true,
                              label : "Height:"
                              fieldName : "Station",
                              visible : true,
                              label : "Station:"
                              fieldName : "StationOffset",
                              visible : true,
                              label : "Station Offset:"
                              fieldName : "Wye",
                              visible : true,
                              label : "Wye:"
                              fieldName : "AccuracyPosition",
                              visible : true,
                              label : "Accuracy Position:"
                              fieldName : "LiftStationNumber",
                              visible : true,
                              label : "Lift Station Number:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              fieldName : "Comment",
                              visible : true,
                              label : "GPS Comments:"
               } else if (result.layerName == "ssLateralPoint") {
                         title : "SS Stubout",
                         fieldInfos : [{
                              visible : true,
                              label : "Stubout Location:"
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Station:"
                              visible : true,
                              fieldName : "Wye",
                              visible : true,
                              label : "Wye:"
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "ssManhole") {
                         title : "SS Manhole",
                         fieldInfos : [{
                              fieldName : "ManholeNumber",
                              visible : true,
                              label : "Manhole No.:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              fieldName : "RimElevation",
                              visible : true,
                              label : "Rim Elevation:"
                              fieldName : "InvertElevation",
                              visible : true,
                              label : "Invert Elevation:"
                              visible : true,
                              visible : true,
                              fieldName : "Lined",
                              visible : true,
                              label : "Lined:"
                              fieldName : "Year_Lined",
                              visible : true,
                              label : "Year Lined:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
                         mediaInfos : [{
                              "title" : "{Hyperlink_ReportA}",
                              "caption" : "Manhole Report",
                              "type" : "image",
                              "value" : {
                                   "linkURL" : "http://fwbgis/Documents/{Hyperlink_ReportA}"
               } else if (result.layerName == "ssNetworkStructure") {
                         title : "SS Network Structure",
                         fieldInfos : [{
                              visible : true,
                              label : "Structure Type:"
                              fieldName : "FacilityID",
                              visible : true,
                              label : "Facility ID:"
                              fieldName : "Name",
                              visible : true,
                              label : "Name:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              fieldName : "Capacity",
                              visible : true,
                              label : "Capacity:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
                         mediaInfos : [{
                              "title" : "{HyperlinkA",
                              "caption" : "Network Structure",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "ssForceMain") {
                         title : "SS Force Main",
                         fieldInfos : [{
                              fieldName : "OBJECTID",
                              visible : true,
                              label : "Force Main:"
                              visible : true,
                              visible : true,
                              fieldName : "PipeDiameter",
                              visible : true,
                              label : "Pipe Diameter:"
                              fieldName : "PipeMaterial",
                              visible : true,
                              label : "Pipe Material:"
                              visible : true,
                              label : "Lined:"
                              visible : true,
                              fieldName : "UpstreamInvert",
                              visible : true,
                              label : "Upstream Invert:"
                              fieldName : "DownstreamInvert",
                              visible : true,
                              label : "Downstream Invert:"
                              fieldName : "Slope",
                              visible : true,
                              label : "Slope:"
                              fieldName : "Shape.len",
                              visible : true,
                              label : "Length:"
                              visible : true,
                              fieldName : "AccuracyInvert",
                              visible : true,
                              label : "Accuracy Invert:"
                              fieldName : "InterpolatedInvert",
                              visible : true,
                              label : "Interpolated Invert:"
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "ssGravityMain") {
                         title : "SS Gravity Main",
                         fieldInfos : [{
                              visible : true,
                              label : "Gravity Main:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Lined:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Slope:"
                              visible : true,
                              label : "Length:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Location:"
                              visible : true,
                              label : "Comments:"
                         mediaInfos : [{
                              "caption" : "TV Report",
                              "type" : "image",
                              "value" : {
                              "title" : "{Hyperlink_VideoA}",
                              "caption" : "TV Video",
                              "type" : "image",
                              "value" : {
                                   "linkURL" : "http://fwbgis/Documents/{Hyperlink_VideoA}"
               }  else if (result.layerName == "ssLateralLine") {
                         title : "SS Lateral Line",
                         fieldInfos : [{
                              visible : true,
                              label : "Lateral Line:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Station:"
                              visible : true,
                              fieldName : "Wye",
                              visible : true,
                              label : "Wye:"
                              visible : true,
                              label : "Length:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "ssFitting") {
                         title : "SS Fitting",
                         fieldInfos : [{
                              visible : true,
                              label : "Sewer Fitting:"
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Station:"
                              visible : true,
                              fieldName : "Wye",
                              visible : true,
                              label : "Wye:"
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "ssSystemValve") {
                         title : "Sewer Valve",
                         fieldInfos : [{
                              visible : true,
                              label : "Valve Type:"
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Diameter:"
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "ssControlValve") {
                         fieldInfos : [{
                              fieldName: "FacilityID",
                              visible: true,
                              label: "Facility ID:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Size:"
                              fieldName : "Manufacturer",
                              visible : true,
                              label : "Manufacturer:"
                              fieldName : "Model",
                              visible : true,
                              label : "Model:"
                              fieldName : "OdorControl",
                              visible : true,
                              label : "Odor Control:"
                              visible : true,
                              label : "In Service Date:"
                              visible : true,
                              label : "Location:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
                         mediaInfos : [{
                              "caption" : "Valve Report",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "swInlet") {
                         title : "SW Inlet",
                         fieldInfos : [{
                              fieldName : "SubtypeCD",
                              visible : true,
                              label : "Inlet Type:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              visible : true,
                              fieldName : "WallMaterial",
                              visible : true,
                              label : "Wall Material:"
                              fieldName : "StructureShape",
                              visible : true,
                              label : "Structure Shape:"
                              fieldName : "Dimension1",
                              visible : true,
                              label : "Dimension1:"
                              fieldName : "Dimension2",
                              visible : true,
                              label : "Dimension2:"
                              fieldName : "AccessType",
                              visible : true,
                              label : "Access Type:"
                              fieldName : "AccessDimension1",
                              visible : true,
                              label : "Access Dimension1:"
                              fieldName : "AccessDimension2",
                              visible : true,
                              label : "Access Dimension2:"
                              visible : true,
                              label : "Positional Accuracy:"
                              visible : true,
                              label : "Invert Accuracy:"
                              visible : true,
                              label : "Invert Interpolated:"
                              fieldName : "BasinNumber",
                              visible : true,
                              label : "Basin Number:"
                              visible : true,
                              label : "Owner:"
                              fieldName : "NoDumpingSign",
                              visible : true,
                              label : "No Dumping Sign:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
                         mediaInfos : [{
                              "caption" : "Inlet Report",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "swOutlet") {
                         title : "SW Outlet",
                         fieldInfos : [{
                              visible : true,
                              label : "Outlet Type:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              visible : true,
                              label : "Comments:"
                              visible : true,
                         mediaInfos : [{
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "swNetworkStructure") {
                         title : "SW Network Structure",
                         fieldInfos : [{
                              visible : true,
                              label : "Network Structure Type:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
                         mediaInfos : [{
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "swHeadwall") {
                         title : "SW Headwall",
                         fieldInfos : [{
                              visible : true,
                              label : "Headwall Facility ID:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              fieldName : "Accuracy",
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
                         mediaInfos : [{
                              "caption" : "Headwall Report",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "swFitting") {
                         title : "SW Fitting",
                         fieldInfos : [{
                              visible : true,
                              label : "Stormwater Fitting:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "swEndwall") {
                         title : "SW Endwall",
                         fieldInfos : [{
                              visible : true,
                              label : "Endwall Facility ID:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
                         mediaInfos : [{
                              "caption" : "Endwall Report",
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "swGravityMain") {
                         title : "SW Gravity Main",
                         fieldInfos : [{
                              visible : true,
                              label : "Gravity Main Type:"
                              visible : true,
                              visible : true,
                              fieldName : "Material",
                              visible : true,
                              label : "Material:"
                              fieldName : "Measurement1",
                              visible : true,
                              label : "Measurement1:"
                              fieldName : "Measurement2",
                              visible : true,
                              label : "Measurement2:"
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Slope:"
                              visible : true,
                              label : "Length:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "swDitches") {
                         title : "SW Ditch:",
                         fieldInfos : [{
                              visible : true,
                              label : "Ditch:"
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Material:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Slope:"
                              visible : true,
                              label : "Length:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "wHydrant") {
                         title : "Fire Hydrant",
                         fieldInfos : [{
                              fieldName : "Fire_Hydrant_Number",
                              visible : true,
                              label : "Fire Hydrant No.:"
                              visible : true,
                              label : "Location:"
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              fieldName : "USNG",
                              visible : true,
                              label : "USNG:"
                              fieldName : "MfYr",
                              visible : true,
                              label : "Manufacture Year:"
                              fieldName : "Manufactur",
                              visible : true,
                              label : "Manufacture:"
                              visible : true,
                              label : "Model:"
                              fieldName : "Size_",
                              visible : true,
                              label : "Size:"
                              fieldName : "Outlet",
                              visible : true,
                              label : "Number of Outlets:"
                              fieldName : "Valve",
                              visible : true,
                              label : "Has a Valve:"
                              fieldName : "Paint_Brand",
                              visible : true,
                              label : "Paint Brand:"
                              fieldName : "CITY_PRIVA",
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "wMeter") {
                         title : "Water Meter",
                         fieldInfos : [{
                              fieldName : "LOCATION ID",
                              visible : true,
                              label : "Water Meter LOCID:"
                              fieldName : "GIS Address",
                              visible : true,
                              label : "Address:"
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              fieldName : "IMPERVIOUS CLASS",
                              visible : true,
                              label : "Impervious Class:"
                              fieldName : "STATUS 1",
                              visible : true,
                              label : "Account Type:"
                              fieldName : "MITIGATION CREDIT",
                              visible : true,
                              label : "Mitigation Credit:"
                              fieldName : "ACCOUNT IMPERVIOUS",
                              visible : true,
                              label : "Account Impervious:"
                              fieldName : "ERU_FINAL",
                              visible : true,
                              label : "ERU Final:"
                              fieldName : "AMOUNT ASSESSED",
                              visible : true,
                              label : "Stormwater Fee:"
                              fieldName : "JURISDICTION",
                              visible : true,
                              label : "Jurisdiction:"
                              fieldName : "METER_NUMBER",
                              visible : true,
                              label : "Meter Number:"
                              fieldName : "SERIAL_NUMBER",
                              visible : true,
                              label : "Register Number:"
                              fieldName : "MeterDiameter",
                              visible : true,
                              label : "Meter Diameter:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "wSystemValve") {
                         title : "Water System Valve",
                         fieldInfos : [{
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              fieldName : "Diameter",
                              visible : true,
                              label : "Diameter:"
                              fieldName : "Hydrant_Valve",
                              visible : true,
                              label : "Hydrant Valve:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "wControlValve") {
                         title : "Water Control Valve",
                         fieldInfos : [{
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Diameter:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "wNetworkStructure") {
                         title : "Water Structure",
                         fieldInfos : [{
                              visible : true,
                              visible : true,
                              fieldName : "Name",
                              visible : true,
                              label : "Name:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Capacity:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
                         mediaInfos : [{
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "wMain") {
                         title : "Water Main",
                         fieldInfos : [{
                              visible : true,
                              label : "Water Main:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Shape Length:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "wLateralLine") {
                         title : "Water Lateral Line",
                         fieldInfos : [{
                              fieldName : "SubType",
                              visible : true,
                              label : "Lateral Line Type:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "wFitting") {
                         title : "Water Fitting",
                         fieldInfos : [{
                              visible : true,
                              label : "Water Fitting:"
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "ruHydrant") {
                         title : "Reuse Fire Hydrant",
                         fieldInfos : [{
                              visible : true,
                              label : "Reuse Fire Hydrant No.:"
                              visible : true,
                              label : "Location:"
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              fieldName : "MfYr",
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Model:"
                              visible : true,
                              label : "Size:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "ruMeter") {
                         title : "Reuse Water Meter",
                         fieldInfos : [{
                              visible : true,
                              visible : true,
                              label : "Address:"
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "ruSystemValve") {
                         title : "Reuse Valve",
                         fieldInfos : [{
                              visible : true,
                              label : "Reuse Valve Type:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Diameter:"
                              visible : true,
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "ruControlValve") {
                         fieldInfos : [{
                              visible: true,
                              visible : true,
                              visible : true,
                              label : "Size:"
                              visible : true,
                              visible : true,
                              label : "Model:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Location:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
                         mediaInfos : [{
                              "type" : "image",
                              "value" : {
               } else if (result.layerName == "ruNetworkStructure") {
                         title : "Reuse Structure",
                         fieldInfos : [{
                              visible : true,
                              label : "Reuse Structure Type:"
                              visible : true,
                              fieldName : "Name",
                              visible : true,
                              label : "Name:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Capacity:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "ruMain") {
                         title : "Reuse Main",
                         fieldInfos : [{
                              visible : true,
                              label : "Reuse Main:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "ruLateralLine") {
                         title : "Reuse Lateral Line",
                         fieldInfos : [{
                              visible : true,
                              label : "Reuse Lateral Line Type:"
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
               } else if (result.layerName == "ruFitting") {
                         title : "Reuse Fitting",
                         fieldInfos : [{
                              visible : true,
                              label : "Reuse Fitting:"
                              visible : true,
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
                              visible : true,
                              label : "Accuracy:"
                              visible : true,
                              label : "Owner:"
                              visible : true,
                              label : "Comments:"
                              visible : true,
               } else if (result.layerName == "ruMonitoringWell") {
                         title : "Reuse Monitoring Well",
                         fieldInfos : [{
                              visible : true,
                              visible : true,
                              visible : true,
                              fieldName : "LAT",
                              visible : true,
                              label : "Latitude:"
                              fieldName : "LON",
                              visible : true,
                              visible : true,
                              label : "Easting:"
                              visible : true,
                              label : "Northing:"
                              visible : true,
                              label : "Height:"
          //Select template based on layer name
          feature.setInfoTemplate(template);
          return feature;
     if (resultsid.length === 0) {
          map.infoWindow.hide();
          return;
     } else {
          map.infoWindow.setFeatures(resultsid);
     map.infoWindow.show(idParams.geometry);
     return resultsid;
function updateDynLayerVisibility() {
     var inputs = dojo.query(".dyn_item");
     for ( i = 0; i < inputs.length; i++) {
          if (inputs.checked) {
               map.getLayer(map.layerIds[inputs.id]).show();
          } else {
               map.getLayer(map.layerIds[inputs.id]).hide();
     if (map.infoWindow.isShowing) {
          runIdentifies({
               mapPoint : idParams.geometry
          //Rerun identify if infowindow is showing
//push only the visible layers that we want to identify to the tasks array
function addIdentMaps() {
     require(["esri/tasks/IdentifyTask"], function (IdentifyTask) {
     tasks = [];
     if (addressLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Addresses/MapServer"));
     if (cdbgLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/CDBG/MapServer"));
     if (annexoLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/AnnexOrdinances/MapServer"));
     if (deedsLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Deeds/MapServer"));
     if (ordinLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Ordinances/MapServer"));
     if (resoluLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Resolutions/MapServer"));
     if (easemLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Easements/MapServer"));
     if (rowLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/ROW_Projects/MapServer"));
     if (brownfLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Brownfields/MapServer"));
     if (citypropLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/CityProperty/MapServer"));
     if (firmLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/FIRM/MapServer"));
     if (firm2016Layer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/FIRM2016/MapServer"));
     if (codeLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/CodeEnforcement/MapServer"));
     if (eluLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/ELU/MapServer"));
     if (zoneLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Zoning/MapServer"));
     if (fluLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/FLU/MapServer"));
     if (garbageLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Garbage/MapServer"));
     if (yardwasteLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/YardWaste/MapServer"));
     if (recyclingLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Recycling/MapServer"));
     if (recyclingdropoffLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/RecyclingDropOff/MapServer"));
     if (hurricaneLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/HurricaneSurge/MapServer"));
     if (elevcertLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/ElevCert/MapServer"));
     if (neighLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Neighborhoods/MapServer"));
     if (wetlandsLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Wetlands/MapServer"));
     if (parksLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Parks/MapServer"));
     if (municipalLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Municipal/MapServer"));
     if (soilLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Soil/MapServer"));
     if (pciLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/PCI/MapServer"));
     if (sewerRLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/SewerReferences/MapServer"));
     if (waterRLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/WaterReferences/MapServer"));
     if (sewertapLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/SewerTaps/MapServer"));
     if (watertapLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/WaterTaps/MapServer"));
     if (subdivLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Subdivisions/MapServer"));
     if (stlightLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/StreetLights/MapServer"));
     if (stsignLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/StreetSigns/MapServer"));
     if (sewerLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/FWBSewer/MapServer"));
     if (stormLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/FWBStormwater/MapServer"));
     if (waterLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/FWBWater/MapServer"));
     if (reuseLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/FWBReuse/MapServer"));
     if (fdotmpLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/FDOTMilepost/MapServer"));
     if (parcelsarLayer.visible == true) {
          tasks.push(new IdentifyTask("http://fwbgis/arcgis/rest/services/Maps/Parcels/MapServer"));
     if (parcelsLayer.visible == true) {
here is lods_extent.js:
function setExts(){
     require(["esri/geometry/Extent"], function (Extent) {
     //set initial extent
    initExtent = new Extent(-9651200, 3555500, -9636400, 3562470, spatialReference);
function setLods() {
lods = [{
               "level" : 4,
               "resolution" : 9783.93962049996,
               "scale" : 36978595.474472
               "level" : 5,
               "resolution" : 4891.96981024998,
               "scale" : 18489297.737236
               "level" : 6,
               "resolution" : 2445.98490512499,
               "scale" : 9244648.868618
               "level" : 7,
               "resolution" : 1222.99245256249,
               "scale" : 4622324.434309
               "level" : 8,
               "resolution" : 611.49622628138,
               "scale" : 2311162.217155
               "level" : 9,
               "resolution" : 305.748113140558,
               "scale" : 1155581.108577
               "level" : 10,
               "resolution" : 152.874056570411,
               "scale" : 577790.554289
               "level" : 11,
               "resolution" : 76.4370282850732,
               "scale" : 288895.277144
               "level" : 12,
               "resolution" : 38.2185141425366,
               "scale" : 144447.638572
               "level" : 13,
               "resolution" : 19.1092570712683,
               "scale" : 72223.819286
               "level" : 14,
               "resolution" : 9.55462853563415,
               "scale" : 36111.909643
               "level" : 15,
               "resolution" : 4.77731426794937,
               "scale" : 18055.954822
               "level" : 16,
               "resolution" : 2.38865713397468,
               "scale" : 9027.977411
               "level" : 17,
               "resolution" : 1.19432856685505,
               "scale" : 4513.988705
               "level" : 18,
               "resolution" : 0.597164283559817,
               "scale" : 2256.994353
               "level" : 19,
               "resolution" : 0.298582141647617,
               "scale" : 1128.497176
               "level" : 20,
               "resolution" : 0.149291444416222,
               "scale" : 564.25
               "level" : 21,
               "resolution" : 0.0746,
               "scale" : 282.12
               "level" : 22,
               "resolution" : 0.0373,
               "scale" : 141.06
               "level" : 23,
               "resolution" : 0.0187,
               "scale" : 70.53
I don't think I'm using IdentifyAll.js. I was just using it as a reference to look over. That file is used for an older application on our website.
Jeremy,
  So you had an issue in your require array:
    require([
      "esri/urlUtils",
      "esri/map",
      "esri/basemaps",
      "esri/config",
      "esri/dijit/Popup",
      "esri/Color",
      "dojo/string",
      "esri/domUtils",
      "dojo/dom",
      "dojo/dom-style",
      "dojo/on",
      "dojo/parser",
      "dojo/_base/array",
      "dijit/TitlePane",
      "dojo/domReady!",
    ], function(
Basics of AMD style coding. You have to have your require array list and your require parameters match order. You had dojo/_base/array after dijit/TitlePane which meant that your array parameter was assigned as a different object class. Also you were using arrayUtils as the parameter name in your code but had it as array in your parameter list.
I fixed the above issues, but it still is not displaying information in the popup window. I think I need something like dojo.connect, like the one here.
But I need it here, I think
I'm not sure if I need that or not.
Jeremy,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #search {
      display: block;
      position: absolute;
      z-index: 2;
      top: 20px;
      left: 74px;
    #mapPane {
      padding: 0;
      height: 100%;
      width: 100%;
    #rightPane {
      width: 20%;
    #legendPane {
    #opacitySliderDiv {
      display: block;
      position: absolute;
      z-index: 2;
      bottom: 20px;
      left: 74px;
  </style>
    var dojoConfig = {
      async: false,
      packages: [{
  </script>
  <script>
    var map;
    var initExtent;
    var lods = [];
    require([
      "esri/urlUtils",
      "esri/map",
      "esri/basemaps",
      "esri/config",
      "esri/dijit/Popup",
      "esri/Color",
      "dojo/string",
      "esri/domUtils",
      "dojo/dom",
      "dojo/dom-style",
      "dojo/on",
      "dojo/parser",
      "dojo/_base/array",
      "dijit/TitlePane",
      "dojo/domReady!",
    ], function(
      parser.parse();
      //Geometry Service
        wkid: 102100
      setLods();
      setExts();
      var basemaps = [];
      var identifyTask;
      var identifyParams;
        extent: initExtent,
        lods: lods,
        map: aerielLayer,
        infoWindow: popup
        basemaps: basemaps,
        map: map
        map: map
      }, "search");
      search.startup();
          visible: true,
          visible: true,
          visible: true,
          visible: true,
          visible: true,
          opacity: 0.5
            map: map,
          }, "legendDiv");
          legend.startup();
        legendLayers.push({
          layer: flu,
              return feature;
  </script>
</head>
    </div>
        </div>
      </div>
    </div>
</body>
</html>
I went through my whole code and nothing was really different except for the function was in a block instead of all being on one line. Now it works! Thank you so much, Robert! I've been banging my head on this for over a week.
