Creating a customisable buffer around points in a feature layer - Javascript API
5115
7
05-23-2012 04:35 AM
RossPudney
I am sorry if this has been posted before - but I have searched the forums before posting and haven't come across anything so my apologies if there is a solution already. I am new to Javascript and am trying to put together a web page which enables me to do the following:
  • Show layers from my ArcGIS Server
  • Enable the user to draw a buffer around the point level feature layer I have in my map (and be able to determine the size of the buffer)
  • Do a query on another polygon layer I have from my Server which intersects with the buffer and provides a sum of the values in a given field column
I am only interested at this stage in finding out how to do the second point and wondered if anyone could help me? I have copy/pasted the ArcGIS resources code for creating a buffer on a click event and inserted into my code below.
The steps I need to understand are:
- How do I make the script draw the buffer around my point layer (it is named asa variable 'Lyr_StrokeUnits') ?
- How do I make the script draw the buffers without the 'onClick' event and instead to draw the buffers dependent on a user input? (Ideally I want the user to be able to input the buffer radius value as they can now and then to be able to press a button to redraw the buffers for all points)
I would be very grateful for any help anyone could give me on this issue.
Kind regards,
Ross
The relevant code below:
function initFunctionality(map) {
        //Identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
        //If this null or not available the buffer operation will not work.  Otherwise it will do a http post to the proxy.
        esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
        esri.config.defaults.io.alwaysUseProxy = false;
        //Geometry Service Endpoint
        var gsvc = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        //Listens for an onClick event in the map
        dojo.connect(map, "onClick", function(evt) {
          map.graphics.clear();
          var params = new esri.tasks.BufferParameters();
          params.geometries  = [ evt.mapPoint) ];
          //Sets the parameters for the buffer in miles and creates the buffer in code, but DOESNT display it
          params.distances = [ dojo.byId('bufferDistance').value ]; //'bufferDistance' is a variable which the user inputs on the main page - found in body code
          params.unit = esri.tasks.GeometryService.UNIT_STATUTE_MILE; // standard miles
          params.bufferSpatialReference = new esri.SpatialReference({wkid: 3857}); //Sets the SRID for the buffer
          params.outSpatialReference = map.spatialReference; //Sets the SRID for the output of the buffer service
          gsvc.buffer(params);
          dojo.byId('messages').innerHTML = "<b>Creating Buffer</b>";
        //Listens for GeometryService onBufferComplete event and then draws the buffer onto the map
        dojo.connect(gsvc, "onBufferComplete", function(geometries) { //gsvc is the centrepoint location where the initial click is recorded
          var symbol = new esri.symbol.SimpleFillSymbol("none", new esri.symbol.SimpleLineSymbol("solid", new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25])); // creates the buffer symbol
          var graphic = new esri.Graphic(geometries[0],symbol); //creates the buffer graphic which is actually displayed onto the map
          map.graphics.add(graphic); //Adds the buffer to the map
          dojo.byId('messages').innerHTML = "<b>Draw Buffer Complete.</b>";
derekswingley1
Remove the "var" from in front of Lyr_StrokeUnit when you create your feature layer in the init function. Removing var will keep Lyr_StrokeUnit as a global. When you use var inside a function, you create a local variable. Because Lyr_StrokeUnit is local to init, that feature layer is not accessible in the drawBuffer function via the Lyr_StrokeUnit variable.
RossPudney
If anyone is able to help me with this I would be so grateful.
derekswingley1
Take the geometries from your feature layer and specify them as your params.geometries. Something like this:
// dojo.map returns an array
// fl is your feature layer
var geoms = dojo.map(fl.graphics, function(g) {
  return g.geometry;
params.geometries = geoms
RossPudney
  return g.geometry;
Thank you Derek - unfortunately that hasn't worked. I have however been editing my code since I posted this afternoon based on other examples and forum questions which seemed to have similar issues. I have removed the actual address to the data I am using from my server as I can't disclose it I am afraid, so I do apologise about that.
I have included it below:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<!-- The HEAD section is the section of code which references and loads all scripts before it is shown on the webpage -->
  <head>
    <title>XXX</title>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/nihilo/nihilo.css">
 <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/esri/dijit/css/Popup.css"/>
 <!--Script 1 loads the Javascript API files -->
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
    <!--Script 2 is where all the code written is executed -->
 <script type="text/javascript">
   //The code script is split into three sections;
   //(1) Reference of a package: Packages are bundles of resources which enable features to work. For adding maps for example
   // the dojo (the underlying basis for Javascript) needs to pull in the 'map' package, hence dojo.require("esri.map") which
   // enables the browser to work with maps
   //(2) Initialisation function(s): The initialisation function(s) are in essence a loading function which adds layers to the map and executes
   // a range of code / processes. As layers can't be physically added, they are pulled from a webservice where appropriate.
   //(3) Script Load: This function runs the specified script, but ensures that the script only runs once the HTML webpage is loaded. This
   // is important as it stops the scripts running BEFORE the map baselayer is loaded.
 //(1) Packages import
   // .require is basically an 'include' function which brings in the resources to display maps
   dojo.require("esri.map"); // creates the map class for all elements to be loaded into
   dojo.require("esri.tasks.query"); // retrieves features from a map layer based on geography or attribute conditions.
      dojo.require("esri.tasks.geometry"); //gives you access to an ArcGIS Server geometry service that can buffer, project, and simplify geometries
   dojo.require("esri.layers.FeatureLayer"); //enables loading of feature layers
   //Pre-load the variables to be used in the script - saves time and memory in terms of processing
   //Base Variables
   var map
   var BaseMap
   //Layer Variables
   var Lyr_StrokeUnits
   var Lyr_UKPopData
   //Task Variables
   var queryTask
   var gsvc
 //(2) Initialisation functions
 //(2.1) Creates a function called init which adds the base map and feature layers used in the map
 function init() {
  //Set the map extent and spatial reference
  var ExtentAndSR = new esri.geometry.Extent(-65000,6000000,-800000,8700000,new esri.SpatialReference({"wkid":3857}));
  //Creates the Map container / object
  var map = new esri.Map("map",{extent:ExtentAndSR});
    //Defines what the variable 'map' does. In this case, it is defined as a Map Class (esri.map)
    //and the 'map' segment provides it with a reference to be displayed in the webpage (ie: The DIV
    //is an object visible in the webpage. As map pulls map data, it is then 'translated' to the DIV
    //element so that it can be shown on the map
  //Listens for when the Map Container is loaded and then adds query functionality in a seperate function after the init script
        dojo.connect(map, "onLoad", initFunctionality);
  //Basemap
  //The underlying raster basemap used in the web portal
   var BaseMap = new //This line and the next defines the variable 'BaseMap' and what basemap will be used
   esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"); //Creates the reference for the variable (ie: where it is coming from)
   map.addLayer(BaseMap); //This adds this layer to the 'base' layer of "map"
  //Layers
  //Layers are loaded in succession - the last layer will be the 'top' layer and so on:
   //Lyr_UKPopData
   var Lyr_UKPopData = new
   esri.layers.FeatureLayer("xxx", {
   mode : esri.layers.FeatureLayer.MODE_ONDEMAND});
   map.addLayer(Lyr_UKPopData);
   //Lyr_StrokeUnits
   var Lyr_StrokeUnits = new
   map.addLayer(Lyr_StrokeUnits);
 //(2.2) Creates a function called initFunctionality(map) which contains the querying scripts for buffer analysis
        function drawBuffer() {
          var buffParams = new esri.tasks.BufferParameters();
    var flgeom = dojo.map(Lyr_StrokeUnits.graphics, function(g) {
    return g.geometry;
          buffParams.geometries = flgeom;
          buffParams.distances = [dojo.byId('bufferDistance').value];
          buffParams.unit = esri.tasks.GeometryService.UNIT_STATUTE_MILE;
          buffParams.bufferSpatialReference = new esri.SpatialReference({wkid:3857});
          buffParams.outSpatialReference = map.spatialReference;
          gsvc.buffer(buffParams, bufferDraw);
    var bufferDraw = dojo.connect(gsvc, "onBufferComplete", function (geometries) {
          var symbol = new esri.symbol.SimpleFillSymbol("none", new esri.symbol.SimpleLineSymbol("solid", new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));
    var graphic = new esri.Graphic(geometries[0], symbol);
 //(3) Script Load
  dojo.addOnLoad(init);
    </script>
  </head>
 <!-- The BODY section which determines the style and positioning of elements in the webpage -->
 <body>
 <body class="nihilo">
 TEST<br>
    Buffer distance (Miles): <input type="text" id="bufferDistance" value="10" size="5"/><input type='button' value='Draw Buffer' onclick='drawBuffer()'/><br>
 <div id="map" style="width: 100%; height: 800px; margin: 0;"></div>
 <span id="messages"></span>
</body>
</html>
You will see that I included your variable solution into the above, and yet I haven't had any joy with it. Do I need to add another dojo.connect somewhere? Or should my 'Draw Buffer' button work?
Thank you for your help so far.
Ross
RossPudney
Is there any further help anyone could offer me on this? Again I would be immensely grateful. It seems that the issue is that my feature layer isn't supply the function with the necessary geometries - anyone know why this might be the case?
derekswingley1
RossPudney
Thank you Derek. That, and the removal of a few extra ';' made it work. I'm very grateful. Thank you.
derekswingley1
Glad to help! And thanks for marking this one answered 🙂
