Creating a custom Map Component
1489
12-06-2024 10:59 AM
DavidOke
I'm working with the new map components @ @https://developers.arcgis.com/javascript/latest/references/map-components/?path=/docs/welcome--do
Is there any documentation on how to create a custom component using the map component paradigm (I.e. what's required to make "MyNewComponent" below work)? The old way was pretty clear with view.ui.add(...). This is a little different:
<ArcGisMap itemId={itemId}>
  <MyNewComponent position="top-left" />
</ArcGisMap>
Thanks!
ReneRubalcava
Esri Frequent Contributor
Currently, you can use the arcgis-placement component for this.
<arcgis-map>
    <arcgis-placement position="top-right">
        <my-custom-component></my-custom-component>
    </arcgis-placement>
</arcgis-map>
ReneRubalcava
<arcgis-map>
    </arcgis-placement>
</arcgis-map>
DavidOke
Thanks! Works perfectly in react and even gets me a reference to the map.
