Creating a Button to Activate Popup - Issue
2004
04-28-2016 09:06 AM
IanPeebles
I have a popup that works well within the application.  However, my goal is to tied the popup to a button, where the user must click on the button to activate the popup.  I keep getting an error in console mode that states" unexpected identifier and the button does not fire the popup.  I have two files, an index.htm and the infoTemplate.js file.  Here are snippets of my code:
index.htm
<script src="js/infoTemplate.js"></script>
<!-- Required Application Modules -->
require([
  "dojo/on",
  "dijit/registry",
  "dojo/dom"
], function(
   on,
   registry,
   dom
  // Code Application Function
  on(dom.byId("btnActivatePopup"), "click", activatePopup);
DIV section
<button id="btnActivatePopup">PopUp</button>
infoTemplate.js
require([
  "esri/dijit/Popup",
  "esri/dijit/PopupTemplate"
], function(
  Popup,
  PopupTemplate
function activatePopup() {
<all of the popup template code in here>
What is it that I am missing?  Any assistance will be appreciated.  Thanks.
williamcarr
Ian,
Are you trying to create the domNode on the button click or just populate it? I use a button click to populate/remove content from an info widow using a domStyle toggle.
To toggle Off:
domStyle.set(query(".actionList > .action.sForm", window.map.infoWindow.domNode)[0], "display", "none");
To toggle On:
domStyle.set(query(".actionList > .action.sForm", window.map.infoWindow.domNode)[0], "display", "");
Don't know if that helps any.
