Create Shapefile
4141
6
08-12-2014 12:49 PM
jaykapalczynski
Honored Contributor
Is it possible to draw on the map - then Create and Export a shapefile
jaykapalczynski
Honored Contributor
I was able to do this with some older code from the link above....see attached zip.
Unzip and create virtual directory on web server
Then navigate in URL to  http:// server info \ js2shapefile\tests\Test_EsriDrawToShapefile.html
Note there is no prj file created....manually project a file to:
Projected Coordinate System:  WGS_1984_world_Mercator , Meter
Then use this .prj file (renamed to output file) and it will render perfectly.
I am going to try and get the code to create this .prj file automatically but cant afford the time now.
NOTE: that this example is using older code and api references I have not yet tried to update these.
RobertScheitlin__GISP
Jay,
   There a couple of javascript libraries that come up in Google when you search.
js2shapefile - ESRI shapefile creator in javascript - Google Project Hosting
You would have to use a library like this. I personally don't have any experience doing this yet but it is an interesting idea.
jaykapalczynski
Honored Contributor
yea this is going to be a touch one....I looked at that example and only a .shp file is exported....no dbf or shx...and written a while ago.....hmmmmm
I tried to bring the files local but not getting the Button to appear to export....have to be doing something wrong...
its using https://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6
anyone else out there dable in exporting a Shapefile from graphic?
RichardDaniels
MVP Regular Contributor
The answer is YES if you are talking about ArcGIS Desktop 10.2.x.
Do the following:
1. Turn on the Drawing toolbar in ArcMap
2. Draw your graphics
3. Select your graphic points, lines, or polygons graphics - can't "mix" the data types
4. Right click on your Data Frame (e.g., "Layers"  by default) in the Table of Contents
5. Select Convert Graphics to Features <-- this is new at 10.2
There are code samples to do this in ArcScripts as well at
http://arcscripts.esri.com/details.asp?dbid=14751
Rich
jaykapalczynski
Honored Contributor
This is for JavaScript API...but thank you for your thoughts
jaykapalczynski
Honored Contributor
RichardDaniels
that just points out how screwed up the new geoNet is.
