Create modal window
7574
13
08-15-2017 01:33 PM
JohnDenis
Is it possible to create a modal window in ArcGIS for JavaScript 3.x ?
I couldn't find this information on GeoNet.
I would like to create and access such a window from a panel: JS BIN code sample.
Thank you,
John
Tags (1)
RobertScheitlin__GISP
Scott,
  I would have to see your code to get a feel for what is wrong.
scottmiller10
I've attached the widget.js and .html files. Thank you for your help!
Scott,
   You should start a new thread in Web AppBuilder Custom Widgets‌ You code has many issues and a clean thread will enable me to go back and forth with you in the appropriate space.
scottmiller10
I just moved it to WAB custom widgets.
