Create Heat Map Based on Array of Points
1266
12-08-2016 03:06 PM
BehrouzHosseini
ArcGIS API is providing a way to generate heat map based on ArcGIS Services like this one at This Example.
Is there any way to generate the heat map based on actual point values on the fly instead of using a service URL. I mean if I have a data like
 var data = [
                    x: -13625078.0408
                    y: 4548494.332400002
                    x: -13625078.0408
is there any way to pass it as Service URL at `heatmapFeatureLayerOptions` like
var heatmapFeatureLayerOptions = {
 mode: data.MODE_SNAPSHOT,
