Create custom widget using "esri/core/accessorSupport/decorators" esri module of version 4.9 and "dijit/_WidgetBase" version 1.11 of dijit module.
1071
11-27-2018 05:02 AM
HarishPalaniappan
i am facing issue with below mentioned code:
/// <amd-dependency path="esri/core/tsSupport/declareExtendsHelper" name="__extends" />
/// <amd-dependency path="esri/core/tsSupport/decorateHelper" name="__decorate" />
import { subclass, declared} from "esri/core/accessorSupport/decorators";
import Evented = require("dojo/Evented");
import _WidgetBase = require("dijit/_WidgetBase");
import ToggleState = require("./ToggleState");
@subclass("compass.widgets.SmallToggleButtonViewModel")
class SmallToggleButtonViewModel extends declared(_WidgetBase, Evented) {
//Getting error Base constructor must all have the Same return type
Can any one help me?
thanks in advance.
Tags (3)
