Country boundaries in ESRI ARCGIS desktop map using javascript
7213
7
02-17-2015 02:40 AM
HemaBahirwani
Hello,
I want to display country boundaries on the arcgis desktop map application, what exactly do we have to use for this?
Tags (1)
FC_Basson
You could use the Esri sample data that is standard with the installation disks or the Esri Web services here: http://server.arcgisonline.com/arcgis/rest/services/Reference
HemaBahirwani
Thank you for your reply. While researching, i did come across this web service, since i am new to esri, i don't know how to incorporate this in my code. If you could please guide me on that, it would be really helpful.
FC_Basson
You can navigate to a specific web service page e.g. http://server.arcgisonline.com/arcgis/rest/services/Reference/World_Boundaries_and_Places_Alternate/... and at the top of the page there are a couple of "View In" options.  For ArcGIS Desktop you can click on the ArcMap link, which will allow you to download a layer file (*.lyr) for ArcGIS Desktop.
FC_Basson
Are you using Legacy or AMD style class referencing?
You add the World reference layer as a Dynamic Map Service layer to your map. The Javascript API reference is here: https://developers.arcgis.com/javascript/jsapi/arcgisdynamicmapservicelayer.html
The code for the constructor will look like this:
var worldDMS = new esri.ArcGISDynamicMapServiceLayer(""http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");
map.addLayer(worldDMS);
HemaBahirwani
Hello,
I tried the code you gave. i added the following :
dojo.require("esri.layers.agsdynamic");
  require([
    "esri/map", "esri/graphic", "esri/symbols/SimpleMarkerSymbol",
    "esri/tasks/GeometryService", "esri/tasks/ProjectParameters",
    "esri/SpatialReference", "esri/InfoTemplate", "dojo/dom", "dojo/on",
    "dojo/domReady!"
  ], function(
    Map, Graphic, SimpleMarkerSymbol,
    GeometryService, ProjectParameters,
    SpatialReference, InfoTemplate, dom, on
and then the code you gave, but it didn't work.
i am using SAP UI5 and have called  <script src="http://js.arcgis.com/3.12/"></script> for map implementation in eclipse
FC_Basson
Your code snippet would not create the map to add any layer to it, so yes my code will not work in that case.
I think the best would be for you to work through the API reference and samples.  You can start here:  https://developers.arcgis.com/javascript/jshelp/intro_firstmap_amd.html
No need for me to repeat what has been explained in many good samples.
HemaBahirwani
Thank you so much. it was of great help.
