Could not locate symbol object properly, it might be misplaced
538
02-13-2022 08:13 PM
jiwuzhao
Description
In the 3D view environment of the CGCS2000 coordinate system, after I add the elevation layer, the graphics layer cannot render the point symbol style, while the polyline and polygon render completely normally. When I don't add an elevation layer, points, polyline , and polygon are all fine. Similarly, if a similar situation does not occur in the 3D view environment of the wgs84 coordinate system, this is a very strange phenomenon, Can the community have a solution to this problem?
Steps to Reproduce
  1. Set the spherical coordinate system to CGCS2000.
  2. Load a DEM layer(CGCS2000).
  3. Draw a point symbol
Environment
  • Version used:4.22
