convert pixel x,y position on map to lat and long?
7519
13
04-20-2020 05:18 AM
CamCode
My map takes up 100% width and height of the browser screen.. I have a draggable div that is super imposed over the map, I am capturing this divs position using offset(); to get the pixel top and left values currently.
My goals would be to convert these values to latitude and longitude... Could something like this be possible?
RobertScheitlin__GISP
Cam,
   Have you considered map.toMap(ScreenPoint)?
https://developers.arcgis.com/javascript/3/jsapi/map-amd.html#tomap
CamCode
Thanks, I thought that may have been depreciated.
So how may that apply to the below scenario for instance?
          let ktop = $('elem').offset().top;
          let ktlft = $('elem').offset().left;
          coordinatesBx = ktop
          coordinatesBy =  ktlft
Cam,
   Not sure what gave you that idea. The application would simply be:
var point = map.toMap(new ScreenPoint(coordinatesBx,coordinatesBy));
console.log("Lat: " + point.getLatitude() + ", Lon: " + point.getLongitude());
CamCode
Gotchya. It is reported Uncaught ReferenceError: ScreenPoint is not defined
did you add the require for the ScreenPoint class?
CamCode
For some reason I am having a hard time in getting the import to resolve; is there a specific order this one should be called?
import ScreenPoint from "esri/geometry/ScreenPoint";
Cam,
  Are you using 4.x or 3.x?
CamCode
Yes, 4.x.. tried to add that as a tag in OP. Is there a similar approach in 4.x?
