Convert JSON data to HTML table
12018
05-24-2017 11:35 AM
srikanthpilli
Hello,
I am looking to find a way where I can convert JSON data to HTML table - where it should capture and display only the "name" and "alias" attributes into the HTML table from the following external json url :
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0?f=pjson
Could you please provide your inputs on it.
Thanks
Srikanth
Tags (3)
KellyHutchins
Esri Notable Contributor
So you just want to show the values for the alias and field name? If so something like this should work.
<!DOCTYPE html>
<html>
<head>
  <title>JSON Content</title>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
  <style>
     table, th, td {
           border: 1px solid #ccc;
           border-collapse: collapse;
      th, td{
        padding:0.5em;
  </style>
  <script src="https://js.arcgis.com/3.20/"></script>
  <script>
    require([
        "dojo/dom",
        "dojo/on",
        "dojo/dom-class",
        "dojo/_base/json",
        "esri/config",
        "esri/request",
        "dojo/domReady!"
      function(
        dom,
        on,
        domClass,
        dojoJson,
        esriConfig,
        esriRequest
          esriConfig.defaults.io.proxyUrl = "url to proxy";
          var requestHandle = esriRequest({
            "url": "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0",
            "content": {
              "f": "json"
          requestHandle.then(createTable, function(error){
            console.log("Request Failed");
        function createTable(response, io){
          var tbl = document.getElementById("tableDiv");
          var tblBody = document.createElement("tbody");
          var header = tbl.createTHead();
          var headerRow = header.insertRow(0);
          var headerCell = document.createElement("th");
          headerCell.innerHTML = "Name";
          headerRow.appendChild(headerCell);
          var headerCell2 = document.createElement("th");
          headerCell2.innerHTML = "Alias";
          headerRow.appendChild(headerCell2);
          response.fields.forEach(function(field){
            var row = document.createElement("tr");
            var cell = document.createElement("td");
            var cell2 = document.createElement("td");
            cell.innerHTML = field.name;
            cell2.innerHTML = field.alias;
            row.appendChild(cell);
            row.appendChild(cell2);
            tblBody.appendChild(row);
          tbl.appendChild(tblBody);
  </script>
</head>
<body>
  <table id="tableDiv"></table>
</body>
</html>
KellyHutchins
<!DOCTYPE html>
<html>
<head>
  <style>
     table, th, td {
      th, td{
        padding:0.5em;
  </style>
  <script>
    require([
        "dojo/dom",
        "dojo/on",
        "dojo/dom-class",
        "dojo/_base/json",
        "esri/config",
        "esri/request",
        "dojo/domReady!"
      function(
        dom,
        on,
        domClass,
        dojoJson,
        esriConfig,
        esriRequest
            "content": {
              "f": "json"
  </script>
</head>
<body>
</body>
</html>
srikanthpilli
Thanks Kelly for looking into it, I copied your code and executed - it doesn't provide any results.
Am I missing anything?
Thanks
Srikanth
KellyHutchins
You'll need to setup a proxy and enter the proxy url on line 38 or use a service running on a server that supports CORS.  Details can be found here:
Using the proxy | Guide | ArcGIS API for JavaScript 3.20
MirHashmi
Here is an implementation of the same solution given by @KellyHutchins through Jquery and without a proxy.  Working link to JSBin
<!DOCTYPE html>
<html>
<head>
  <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.11.0/jquery.min.js"></script>
  <script type="text/javascript">
          $(document).ready(function(){
                    $.ajax({
                         url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0",
                         data: "f=pjson",
                         success: function (data) {
                              //console.log(data);
                              createTable(data);
          function createTable(response){
          JSON.parse(response).fields.forEach(function(field){
  </script>
</head>
<body>
</body>
</html>
