Convert button click event (Coordinate conversion)
880
05-17-2023 01:12 PM
MaicollDavidArizaCoronado
I am using the CoordinateConversion widget and I want to take the click event of the button that converts the coordinates. I plan to use this event to add other independent functionalities to the widget, for example to prevent the view from changing if it has entered incorrect coordinates, does anyone know what the event is or know of an alternative to this?
JoelBennett
MVP Regular Contributor
This is another one that cannot be done with documented means.  However, it is easily done by replacing the _processUserInput method:
const ccWidget = new CoordinateConversion({
	view: view
ccWidget._processUserInput = function() {
	alert("Convert clicked...");
view.ui.add(ccWidget, "bottom-left");
However, that will disconnect it from its default logic, and it would be entirely up to your custom code to handle the event.  If you want to keep the existing default logic, then you would do something like this:
	view: view
ccWidget._defaultProcessUserInput = ccWidget._processUserInput;
	var useDefault = false;
	//custom code
	if (useDefault)
		this._defaultProcessUserInput();
Note also that typing in the textbox will also cause this same handler to execute.
Also...with all these hacks, my unsolicited opinion is that you may be better off creating your own widget/user interface, and leveraging the SDK's internal logic via an instance of CoordinateConversionViewModel.
