Context of 'this' gets lost while adding graphic to map
1585
12-19-2013 10:41 AM
JimWharton
I have declared a class that adds a draw toolbar and an edit toolbar and an UndoManager.
define([   "dojo/on",   "dojo/dom",   "dojo/_base/event",   "dojo/_base/declare",   "dijit/_WidgetBase",   "dijit/_TemplatedMixin",   "dojo/text!./templates/DrawingToolsWidget.html",    "esri/toolbars/draw",   "esri/toolbars/edit",   "esri/graphic",    "esri/symbols/SimpleMarkerSymbol",   "esri/symbols/SimpleLineSymbol",   "esri/symbols/SimpleFillSymbol",   "esri/geometry/Point",   "esri/geometry/Polygon",   "esri/geometry/jsonUtils",   "esri/undoManager",   "dojo/_base/Color",    "dojo/domReady!" ],   function(     on,     dom,     Event,     declare,     _WidgetBase,     _TemplatedMixin,     template,     Draw,     Edit,     Graphic,     SimpleMarkerSymbol,     SimpleLineSymbol,     SimpleFillSymbol,     Point,     Polygon,     geometryJsonUtils,     UndoManager,     Color) {      return declare("DrawingToolsWidget",[_WidgetBase, _TemplatedMixin], {       templateString: template,       map:{},       toolbar:{},       symbol:{},       editToolbar:{},       selected:{},       currentLocation:{},       undoManager:{},        constructor: function(map) {         this.map = map;         this.undoManager = new UndoManager();       },       postCreate: function() {         console.log(this.undoManager);         this.createToolbar();       },       chooseTool: function(e) {         Event.stop(e);         var tool = e.target.id;         console.log(tool);         this.activateTool(tool);       },       activateTool: function(tool) {         // tool = tool.toUpperCase().replace(/ /g, "_");         this.toolbar.activate(Draw[tool]);         this.map.hideZoomSlider();       },       chooseMoveTool: function(e) {         Event.stop(e);         var self = this;         this.toolbar.deactivate();         self.editToolbar = new Edit(this.map);         // this.editToolbar.deactivate();         this.map.graphics.on("click", function(evt) {           self.selected = evt.graphic;           // console.log(self.selected);           self.editToolbar.activate(Edit.MOVE, evt.graphic);         });        },       chooseDeleteTool: function(e) {         Event.stop(e);         var self = this;         this.toolbar.deactivate();         this.map.graphics.on("click", function(evt) {           map.graphics.remove(evt.graphic);         });       },       createToolbar: function() {         this.toolbar = new Draw(this.map);         this.toolbar.on("draw-end", this.addToMap);       },       undo: function(e) {         Event.stop(e);         this.undoManager.undo();       },       redo: function(e) {         Event.stop(e);         this.undoManager.redo();       },       addToMap: function(evt) {         var symbol;         console.log(this.undoManager);         // this.toolbar.deactivate();         this.map.showZoomSlider();         switch (evt.geometry.type) {           case "point":           case "multipoint":             symbol = new SimpleMarkerSymbol();             break;           case "polyline":             symbol = new SimpleLineSymbol();             break;           default:             symbol = new SimpleFillSymbol();             break;         }         var graphic = new Graphic(evt.geometry, symbol);         var operation = this.map.graphics.add(graphic);         this.undoManager.add(operation); //<-- this returns undefined, but the reference to this.map above it is fine.       },       deactivateToolbar: function(e) {         Event.stop(e);         this.toolbar.deactivate();       }      });    }  );
When I set a breakpoint or console.log out the 'this' object in the addToMap method, I get the 'Window' object. Which makes me wonder why 'this.map' is working just fine.
How can I get the context of 'this' to be the class I've declared so I can push an operation onto the UndoManager's stack?
ReneRubalcava
Esri Frequent Contributor
Odd, I would think the context for this would the toolbar, but you can bind the context of your widget to the addToMap function using dojo/_base/lang.
Instead of
Try
this.toolbar.on("draw-end", lang.hitch(this, "addToMap"));
That should make sure your addToMap method has a context bound the widget.
ReneRubalcava
Instead of
Try
JianHuang
As Rene pointed out, it should be hitched.
The reason you are seeing that this.map is still available is probably you have map as a global variable defined in your application.
JimWharton
Thank you both for the insight. I do usually keep 'map' in a global while developing so that it's easy to just peek at it on the dev console.
And yes, dojo.hitch did the trick. I never really knew what that was for, so thanks for the quick lesson.
-Jim
