ContentPane Visibility
3761
10-05-2012 10:04 PM
Town_ofSnowflake
I'd like a ContentPane to be hidden on page load, then make it visible dynamically when a particular event is triggered. I'm trying to complete this only using Dojo.
...  seems like it should be relatively easy, but I can't figure it out.
StephenLead
Honored Contributor
One approach could be to set the content pane's CSS to display: none; by default, then modify it inside the event:
dojo.connect(element, "event", function(evt) {  document.getElementById("contentPaneId").style.display = 'block';
Steve
Town_ofSnowflake
Hi Steve-
I've done exactly this.  Within the HTML, when I declare the div:
<div id="attribcent" dojotype="dijit.layout.ContentPane" region="right" style="display: none">
Then, when the method is called, I have this line within the method:
document.getElementById("attribcent").style.display = 'block';
