Content Pane & Button Placements?
8421
11
05-18-2016 08:46 AM
NMWater
Hi all!
I'm having a bit of trouble getting my home button to align correctly inside a content pane. I'm trying to place it under the zoom in/ zoom out button.  Below is my CSS and my style. I tried placing it under my map div but that didn't work. Any suggestions?
Body:
CSS:
RESULTS:
RobertScheitlin__GISP
Francisco,
  The issue is in the comment inside your style block.
Change to this and you will be good to go:
  <style>
    html, body, #map{
      height: 100%;
      width:100%;
      margin:0;
      padding:0;
    #HomeButton {
      display: block;
      position: absolute;
      top: 90px;
      left: 20px;
      z-index: 2;
  </style>
RickeyFight
This is where I have mine:
**I used the locate button in this example**
JS:
<div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;">
                <div id="LocateButton"></div>
                <div id="HomeButton"></div>
            </div>
CSS:
       #LocateButton {
                position: absolute;
                top: 95px;
                left: 20px;
                z-index: 50;
NMWater
Hi Rickey,
I tried placing it the way you suggested it, still no luck though.
Any ideas what else could be causing the alignment?
Best,
Francisco
RickeyFight
Can you post all your code or send a link to your site?
NMWater
Hi Rickey, This is my code:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <title>Test Table</title>
  <script src="https://js.arcgis.com/3.16/"></script>
  <link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
  <style>
    html, body, #map{
  height: 100%;
      width:100%;
      margin:0;
      padding:0;
  <!-- This is the Home Button -->
  #HomeButton {
  display: block;
  position: absolute;
  top: 90px;
  left: 20px;
  z-index: 2;
  </style>
  <script>
  var map='';
    require([
      "esri/layers/FeatureLayer",
      "esri/dijit/FeatureTable",
   "esri/dijit/HomeButton",
   "esri/layers/ArcGISDynamicMapServiceLayer",
   "esri/layers/ImageParameters",
      "esri/geometry/webMercatorUtils",
      "esri/map",
      "dojo/dom-construct",
      "dojo/dom",
      "dojo/parser",
      "dojo/ready",
      "dojo/on",
      "dojo/_base/lang",
      "dijit/registry",
      "dijit/form/Button",
      "dijit/layout/ContentPane",
      "dijit/layout/BorderContainer",
      "dijit/form/TextBox"
    ], function (
      FeatureLayer, FeatureTable, HomeButton, ArcGISDynamicMapServiceLayer, ImageParameters, webMercatorUtils, Map,
      domConstruct, dom, parser, ready, on,lang,
      registry, Button, ContentPane, BorderContainer, TextBox
      parser.parse();
      ready(function(){
        var myFeatureLayer;
        var map = new Map("map",{
          basemap: "streets",
   center:[-105.89, 34.55],
   zoom: 6,
   showLabels : "True",
   logo: false,
  var home = new HomeButton({
  map: map
  }, "HomeButton");
  home.startup();
  //This connects the Table to the Map
        map.on("load", loadTable);
  // This sets the image parameters from the RASTERS from the Map Service
  var imageParameters =new ImageParameters();
  imageParameters.format = "jpeg";
  // This adds the RASTERS from the Map Service
  var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://128.123.187.240:6080/arcgis/rest/services/TEST_ET/ET_SSEB/MapServer",{
  "opacity" : 0.95,
  "imageParameters" : imageParameters
  dynamicMapServiceLayer.setVisibleLayers([0]);
  var layerDefinitions = [];
  layerDefinitions[0] = "Year";
  dynamicMapServiceLayer.setLayerDefinitions(layerDefinitions);
  map.addLayers([dynamicMapServiceLayer]);
        function loadTable(){
          // Create the feature layer
          myFeatureLayer = new FeatureLayer("http://128.123.187.240:6080/arcgis/rest/services/TEST_ET/ET_SSEB_YEARLY/MapServer/3", {
            mode: FeatureLayer.MODE_ONDEMAND,
            visible: true,
            outFields: ["*"],
          //set map extent
          on(myFeatureLayer, "load", function(evt){
            var extent = myFeatureLayer.fullExtent;
            if (webMercatorUtils.canProject(extent, map)) {
              map.setExtent( webMercatorUtils.project(extent, map) );
          map.addLayer(myFeatureLayer);
          myFeatureTable = new FeatureTable({
            "featureLayer" : myFeatureLayer,
            "outFields":  ["F2004","name"],
            "map" : map
          }, 'TestTable');
          myFeatureTable.startup();
          on(myFeatureTable, "load", function(evt){
            console.log("The load event - ", evt);
          myFeatureTable.on("show-statistics", function(evt){
            console.log("show-statistics avgfield - ", evt.statistics.avgField);
            console.log("show-statistics countfield - ", evt.statistics.countField);
            console.log("show-statistics maxfield - ", evt.statistics.maxField);
            console.log("show-statistics minfield - ", evt.statistics.minField);
            console.log("show-statistics stddevfield - ", evt.statistics.stddevField);
            console.log("show-statistics sumfield - ", evt.statistics.sumField)
          myFeatureTable.on("row-select", function(evt){
            console.log("select event - ", evt[0].data);
          myFeatureTable.on("row-deselect", function(evt){
            console.log("deselect event - ", evt[0].data);
          myFeatureTable.on("refresh", function(evt){
            console.log("refresh event - ", evt);
          myFeatureTable.on("column-resize", function(evt){
            //triggered by ColumnResizer extension
            console.log("column-resize event- ", evt);
          myFeatureTable.on("column-state-change", function(evt){
            // triggered by ColumnHider extension
            console.log("column-state-change event - ", evt);
          myFeatureTable.on("sort", function(evt){
            console.log("sort event - ", evt);
          myFeatureTable.on("filter", function(evt){
            console.log("filter event - ", evt);
  </script>
</head>
<body class="claro esri">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:true" style="height:50%">
  <div id ="map" class="map">
  </div>
    </div>
    <div id="bot" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:true" style="height:50%">
      <div id="TestTable"></div>
    </div>
  </div>
</body>
</html>
Francisco,
  You should always place another div inside the ContentPane that has the id where you will place your map (don't give a contentpane the id="map"):
      <div id="map" class="map">
      </div>
    </div>
NMWater
Hi Robert,
Thanks for all your help!
I added the class="map." However, I kept getting the following result.
Francisco,
  <style>
    html, body, #map{
      height: 100%;
      width:100%;
      margin:0;
      padding:0;
    #HomeButton {
      display: block;
      position: absolute;
      top: 90px;
      left: 20px;
      z-index: 2;
  </style>
NMWater
Robert! You saved the day!
I know that in JS you can use two // to comment out. Is there any way to comment in the style part of the HTML?
Many many thanks!
Yes it is
/* This is the Home Button */
