Connect to geodatabase or cad file by JavaScript Api
3454
01-05-2013 06:02 AM
AmmarAssem1
How I can read data from cad file in Server hard disk directly when i using javascript api
HemingZhu
Have you thought about create a geoprocesing service and used it in your JS API apps?
AmmarAssem1
Hi hzhu,
Did you mean I create geoprocessing task convert data from cad file or from SDE GeoDatabase to json and return json data??
I created geoprocessing task convert cad file to shape file, then compress shape file to zip extension and using this zip file in my
JavaScript API application but i need to work directly with cad file not with zip file
Best wishes.
HemingZhu
Hi hzhu,
Best wishes.
arcpy treated a cad file as dataset, you could open a cad file reading the layers(point, ployline, polygons etc) inside a cad file....
AmmarAssem1
Thanks hzhu,
I will searching about arcpy but can I work with vba instead of arcpy ????
Best Wishes
