Confuse API reference notes esri.geometry.lngLatToXY(long, lat, isLinear)
1543
02-07-2013 06:59 AM
AdrianMarsden
Honored Contributor
OK - late in the day here but on
http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/#namespace_geometry/esri.geometry.lngLatToX...
For esri.geometry.lngLatToXY(long, lat, isLinear)
the example is
 var normalizedVal = esri.geometry.xyToLngLat(42215329, 1321748);
 console.log(normalizedVal); //returns 19.226, 11.789
 var value = esri.geometry.xyToLngLat(42215329, 1321748, true);
 console.log(value); // returns 379.22, 11.78
But the part for esri.geometry.xyToLngLat(long, lat) has no examples
Am I just confused?  All I am trying to do is use these to go from UK WKID (27700) to google map friendly co-ordinates (I realise there may be a small error, but all I need is a good approximation)
Cheers
ACM
KellyHutchins
Esri Notable Contributor
Adrian,
Those methods are only for converting from Web Mercator to Geographic and the reverse. If you want to convert to another coordinate system take a look at the Geometry Service's project method:
http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/#GeometryService/project
AdrianMarsden
Honored Contributor
Thanks for that - I realize I probably need the projecyt method - however what the post was really about was the mis-match between thing and the snippet the (it is under the esri.geometry.lngLatToXY but the snippet is for XYTolngLat.
Cheers
ACM
KellyHutchins
Ok now I get it - we'll get the error fixed in the documentation for the next release.
Kelly
